Instant Interrupts - Revisited
Results 1 to 40 of 773
    I am still at 2.50c and although I have an itch to upgrade to 2.60 I do no think I'll do it now.
    Darrel, If one uses MCS to edit and complile (with MPASM assembler) is there a problem?
    Am I following this correctly?
    The problem is not with the new PBP it is with the new MPLAB?
    Does it work with the MPLAB that we used with PBP 2.5?
    Wink
    Hi, Dave and Ioannis
    YES ...
    I really think it's URGENT to wait a little !!!
    BUT it seems the problem only Occurs with DT 18 Instant Interrupts ...
    So other includes with ASM work properly?
    That would be strange...
    Thanks Alain.
    But with MCS does it compile OK?
    Smile
    Thanks Alain.
    Hi, Ioannis
    I've verified in real life ... my old programs Work fine, compiled With MCS.
    Was not so evident due to little changes in the resulting HEX ...
    Dec 2005
    Darrel,
    In my PBP code the only assembly routine would be your code for the interrupt and I have no branch routines. My interrupt routine is in PBP, not assembly, but if is was, could this then be a possible issue. Also in searching this thread, I did see the possibly of inserting "@ errorlevel -306 " to suppress the warning, if this is a OK, where does it makes sense to insert it, such as right after the includes.
    Thanks for your help,
    Terry
    NOT TRUE!
    As explained in the previous posts, the problem will happen with ANY program that uses PBP statements inside of macro's, when using MPLAB<hr>
    Ioannis,
    PBP 2.60 is really nice. And it works really well with Microcode Studio.
    MPLAB is the problem. But trying to make PBP work with the new MPLAB, meLabs made a mistake, and now it causes new problems.
    Don't wait, go ahead and get the upgrade, but forget about MPLAB.
    Wink
    NOT TRUE!
    Hi, Darrel
    You should have understood :
    It works with "DT_INTS-14.bas" ... but not with "DT_INTS-18.bas"
    Its a pity to have also lost the PBP label NAMES ...
    Dec 2005
    Darrel,
    Quick question, off topic from the most recent posts. I am using a PIC16F876A part with the DT_INTS-14.bas and using a timer0 interrupt, everything works wonderful, many many thanks! but when my program size goes past the 2k size I get the message when compiling "Message[306] ... Crossing page boundary -- ensure page bits are set." while I know this is only a warning, my program seems to work fine, but I would like to double check, whether this is a concern or not.
    Terry
    Hi Terry,
    DT_INTS won't have any problems when it crosses page boundaries, and most normal PBP programs won't either.
    But if the program uses the BRANCH command or has assembly language routines, it can be a problem.
    Crossing Page Boundary - Solution
    http://www.picbasic.co.uk/forum/showthread.php?t=40
    Warning (and other Compilation Error) Messages (Melanie)
    http://www.picbasic.co.uk/forum/showthread.php?t=555
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
