Here is the errors I get
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Pic Programs\Blink i.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F1220 "Blink i.asm" /l"Blink i.lst" /e"Blink i.err"
Warning[230] C:\PBP\18F1220.INC 20 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] C:\PBP\18F1220.INC 21 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] C:\PBP\18F1220.INC 22 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] C:\PBP\18F1220.INC 23 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Error[105] C:\PIC PROGRAMS\BLINK I.ASM 204 : Cannot open file (Include File "BLINKI~2.MAC" not found)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 219 : Found label after column 1. (DDISABLE?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 227 : Found label after column 1. (GOTO?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 227 : Illegal opcode (_OVER_DT_INTS_18)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 231 : Found label after column 1. (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 369 : Found label after column 1. (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 374 : Found label after column 1. (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 392 : Found label after column 1. (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 397 : Found label after column 1. (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 696 : Found label after column 1. (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 701 : Found label after column 1. (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 714 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 714 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 719 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 719 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 758 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 758 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 763 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 763 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 782 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 782 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 787 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 787 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 793 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 793 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 798 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 798 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 852 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 852 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 857 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 857 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 914 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 914 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 919 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 919 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 969 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 969 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 974 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 974 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1044 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1044 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1049 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1049 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1126 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1126 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1131 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1131 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1224 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1224 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1229 : Found label after column 1. (LABEL?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1229 : Illegal opcode (_OVER_DT_INTS_18)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1232 : Found label after column 1. (DENABLE?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1237 : Found label after column 1. (DDISABLE?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1237 : Address label duplicated or different in second pass (DDISABLE?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1244 : Found label after column 1. (GOTO?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1244 : Illegal opcode (_OverReEnterH)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1248 : Found label after column 1. (LABEL?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1248 : Illegal opcode (_SavePBP_H)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1251 : Found label after column 1. (CMPNE?TCL)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1251 : Illegal opcode (PB01)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1267 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1267 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1277 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1277 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1315 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1315 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1335 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1335 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1340 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1340 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1395 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1395 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1402 : Found label after column 1. (LABEL?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1402 : Illegal opcode (L00001)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1406 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1406 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1409 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1409 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1414 : Found label after column 1. (LABEL?L)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1414 : Illegal opcode (_RestorePBP_H)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1417 : Found label after column 1. (CMPNE?TCL)
Error[122] C:\PIC PROGRAMS\BLINK I.ASM 1417 : Illegal opcode (PB01)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1433 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1433 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1443 : Found label after column 1. (ENDASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1443 : Address label duplicated or different in second pass (ENDASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1481 : Found label after column 1. (ASM?)
Error[116] C:\PIC PROGRAMS\BLINK I.ASM 1481 : Address label duplicated or different in second pass (ASM?)
Warning[207] C:\PIC PROGRAMS\BLINK I.ASM 1501 : Found label after column 1. (ENDASM?)
(rest of errors deleted)
Halting build on first failure as requested.
BUILD FAILED: Fri Jul 31 16:45:07 2009
