Any type of software timed commands like SERIN/OUT, OWIN/OUT, PAUSE, PULSIN/OUT etc, will be disturbed by these types of Interrupts.
Since you have 4 different things interrupting, the software timing is getting messed up pretty bad.
If you only needed the transmit side, you could use ...
Tmr_tx-18
http://www.picbasic.co.uk/forum/show...1&postcount=28
But it sounds like you need the RX side too.
With a need for 3 USART's, You may be out of luck.
