Instant Interrupts - Revisited
Results 1 to 40 of 773
    Mar 2008
    london
    This is a series of include files that simplify the process of creating interrupt driven programs for PicBasic Pro. MPASM required.
    Once you try this, you may never use ON INTERRUPT again.
    <table border=0 cellpadding=5><tr><td valign=top>
    Features:
    Assembly language Interrupts
    Basic language Interrupts
    Both ASM and Basic interrupts in the same program
    Service Multiple Interrupt sources
    Prioritized execution order
    Very easy to use
    No ON INTERRUPT "Code Bloat"
    No ON INTERRUPT " I'll service your interrupt
    &nbsp; whenever I feel like it." mentality.
    One of the best things about this system, is that you don't have to remember where all the Enable bits and Interrupt flags are located.
    Each interrupt "source" is given a unique name that is used to reference it. The system "Looks Up" the correct bit locations for that name. &nbsp; Reducing those RTFM sessions to a minimum. &nbsp; The table to the right lists the Named Interrupts.
    </td><td ><table border=1 cellpadding=5><tr><td valign=top nowrap> <center><b>Available Interrupt Sources</b> &nbsp; 14-bit</center><pre> INT_INT -- INT External Interrupt<br> RBC_INT -- RB Port Change Interrupt<br> TMR0_INT -- TMR0 Overflow Interrupt 16F<br> TMR1_INT -- TMR1 Overflow Interrupt<br> TMR2_INT -- TMR2 to PR2 Match Interrupt<br> TX_INT -- USART Transmit Interrupt<br> RX_INT -- USART Receive Interrupt<br> CMP_INT -- Comparator Interrupt<br> EE_INT -- EEPROM/FLASH Write Operation Interrupt<br> BUS_INT -- Bus Collision Interrupt<br> PSP_INT -- Parallel Slave Port Read/Write Interrupt<br> AD_INT -- A/D Converter Interrupt<br> SSP_INT -- Master Synchronous Serial Port Interrupt<br> CCP1_INT -- CCP1 Interrupt<br> CCP2_INT -- CCP2 Interrupt</pre></td></tr></table></td></tr></table>Here's a simple example of toggling an LED using the external interrupt (INT). (Hello World)
    <font color="#000000"><b>LED1   </b><font color="#008000"><b>VAR  </b></font><b>PORTB</b>.<b>1
    </b><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;DT_INTS-14.bas&quot;     </font><font color="#0000FF"><b><i>' Base Interrupt System
    </i></b></font><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;ReEnterPBP.bas&quot;     </font><font color="#0000FF"><b><i>' Include if using PBP interrupts
    </i></b></font><font color="#008000"><b>ASM
    </b></font><font color="#000080">INT_LIST  macro    </font><font color="#0000FF"><b><i>; IntSource,        Label,  Type, ResetFlag?
            </i></b></font><font color="#000080">INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
        INT_CREATE               </font><font color="#0000FF"><b><i>; Creates the interrupt processor
        </i></b></font><font color="#000080">INT_ENABLE   INT_INT     </font><font color="#0000FF"><b><i>; enable external (INT) interrupts
    </i></b></font><font color="#008000"><b>ENDASM
    </b></font><b>Main</b>:
      <font color="#008000"><b>PAUSE </b></font><b>1
    </b><font color="#008000"><b>GOTO </b></font><b>Main
    </b><font color="#0000FF"><b><i>'---[INT - interrupt handler]---------------------------------------------------
    </i></b></font><b>ToggleLED1</b>:
         <font color="#008000"><b>TOGGLE </b></font><b>LED1
    </b><font color="#000080">@ INT_RETURN</font>
    <font size=-2>Code Size = 234 words</font>
    <script language="javascript" src="http://www.darreltaylor.com/files/forum_ii.js"></script>
    This project, and it's associated files, have been moved.
    Please download them from my website.
    DT_INTS-14 (12F-16F)
    http://darreltaylor.com/DT_INTS-14/intro.html
    DT_INTS-18 (18F)
    http://darreltaylor.com/DT_INTS-18/home.html
    hello,
    i just tested the program with the 16f88 but it s not working , there are some error messages.
    dont know exactly what to do next
    can u give me some advices please??
    thanx
    NO.. at least give more details... error message, code etc etc
    Make sure you're using MPASM to compile
    Judging from the:
    @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
    in the rest of the posts...hmmmmmmmmmmm........
    Jul 2007
    WoW!
    those routines works like magic for a noobie like me
    I've found out that most of my code must be done inside the interrupt part, otherwise if it's in the Main loop it can get trashed by the interrupt(like SEROUT to a serial LCD), but it got my
    latest project running very quickly.
    tnx Darrel
    Default Int_return
    First of all thanx for the code my interups now gets handeled fast enoug so i dont loose any serial data, one problem for some reason my program do not return from the interupt.
    Any ideas
    i use a 16f913
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    DEFINE OSC 20				' Define crystal as 20Mhz
    '*Serial port Setup 9600 8N1*
    DEFINE HSER_BAUD 9600 		; 9600 Baud
    DEFINE HSER_RCSTA 90h 		' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h 		' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1  		; Clear overflow automatically
    '*ADC setup*
    DEFINE ADC_BITS 10 			'SETS NUMBER OF BITS IN RESULTS 8,10,12
    DEFINE ADC_CLOCK 3 			'SETS CLOCK SOURCE (RC = 3)
    DEFINE ADC_SAMPLEUS 50 		'SETS SAMPLING TIME IN MICROSECONDS
    'This Part set PORTA 0-5 an analog inputs
    ADCON1 = %01110000			'FRC (clock derived from a dedicated internal oscillator = 500 kHz max)
    ANSEL  = %00011111			'The ANSEL (91h) and CMCON0 (9Ch)registers must be initialized to configure an
    CMCON0 = %00000111			'analog channel as a digital input. Pins configured as analog inputs will read ‘0’.
    TRISA  = %00011111			'set PORTA 0-5 as inputs
    ADCON0.7 = 1				'Right justify output of ADC datasheet P145 of 16F913
    TRISC = %10000000			'Set PORTC for serial coms and pins  as output
    TRISB = %00000000			'Sert PORTb as outputs and for use with the ICD2
    V1 var WORD
    ID var byte[28]
    CELL1	VAR BYTE[11]
    I	VAR BYTE
    PORTC = 0
    INT_LIST  macro ; IntSource,        Label,  Type, ResetFlag?
        INT_Handler    RX_INT,  _IntLoop,   ASM,  yes
        INT_CREATE               		; Creates the interrupt processor
    	INT_ENABLE   RX_INT     		; enable external (RX) interrupts
    		PORTC.5=1
    		PAUSE 200
    		PORTC.5=0
    		PAUSE 200
    		PORTC.5=1
    		PAUSE 200
    		PORTC.5=0
    goto Main
    IntLoop:
    	HSERIN [WAIT("^SMGL:"),SKIP 1 ,str ID\28]
        HSEROUT ["CELL NO:",_
              ID[17],iD[18],ID[19],ID[20],ID[21],ID[22],_
              ID[23],ID[24],ID[25],ID[26],ID[27],10,13]
    @ INT_RETURN
    As you're using HSERIN/HSEROUT, shouldn't RX_INT be PBP type instead?
    Don't forget to add ReEnterPBP.bas in your INCLUDE list.
    Feb 2005
    Kolkata-India
    Talking Mister-e is right.
    I thought I could point this out. This forum is fortunate that there are less people like me. Late and lazy.
    BTW Steve everytime I see the avatar banging head on the keyboard I feel concerned. Please stop banging your head. Its costly. I mean the keyboard that is...
    Sougata
    As Steve noted on many post before:
    We are not fortune tellers here. More input as Johnny 5 said once!
    Jun 2008
    Well,
    First I was asking if someone has problems with INT when using the BPI-216 LCD.
    Anyway,
    When using this code on my 16F887, The LCD gets freaked.
    I will just display junk. I tried to eliminate some of the timers, and as said before, When having only INT for button or for clock it reduce the junk.
    Other code which implemets clock without INT but just timer, (http://www.picbasic.co.uk/forum/showthread.php?t=2129) works perfect with this LCD.
    Here is the code that makes it go crazy:
    LED1   VAR  PORTD.0
    LED2   VAR  PORTD.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INCLUDE "Elapsed_INT.bas"    ' Elapsed Timer Routines
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    OPTION_REG = OPTION_REG & $80 | 1  ; Set TMR0 Prescaler to 256, leave RBPU alone
    @    INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    @    INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
    @    INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    GOSUB ResetTime              ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer             ' Start the Elapsed Timer
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
            IF Hours>9 THEN
              SEROUT PORTB.1,6,[254,128,#Hours,58]
              pause 300
                  SEROUT PORTB.1,6,[254,128,48,#Hours,58]
                  pause 30
            IF Minutes>9 THEN
              SEROUT PORTB.1,6,[254,131,#Minutes,58]
              pause 300
                  SEROUT PORTB.1,6,[254,131,48,#Minutes,58]
                  pause 300
            IF Seconds>9 THEN
              SEROUT PORTB.1,6,[254,134,#Seconds]
              pause 300
                  SEROUT PORTB.1,6,[254,134,48,#Seconds]
                  pause 300
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    '---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
    T0Count  VAR WORD
    ToggleLED2:
        T0Count = T0Count + 1
        IF T0Count = 512 THEN T0Count = 0 : TOGGLE LED2
    @ INT_RETURN
    Jun 2008
    btw,
    If I disable INT (INTCON=0) the LCD shows correctly, but of ocurse interrupts are not working.
    Dec 2003
    Storrs, Ct.
    What I do is turn off interrupts before serial and back on after serial completes. Like this:
    sendudp:
            INTCON.7 = 0
            SerOut2 PORTC.6, 84, [$50] 'ask siteplayer to send udp
            INTCON.7 = 1
            udpcount = 0
            gosub delay
    Somewhere in here there is a list of the commands affected by Instant interrupts. I just turn the interrupts off, execute the command and turn the interrupts back on.
    I'm not sure if this is the best way to handle things but it's worked well for me so far.
    Hope this helps.
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Jun 2008
    Well,
    What if the interrupts are for the clock ?
    Disabling it will cause the clock not to keep going.
    Jun 2005
    Hi--
    I'm having a problem with Instant Interrupts that I can't figure out... I'm using Darrell's Elapsed Timer with V3.2 of DT_INTS-18 and Reenter-PBP-18. The chip is an 18F4520 running at 16MHz. The interrupt-driven elapsed timer system works beautifully, but then I can no longer use the second PWM output, CCP2, which I have set up to output on portc.1. CCP1 works perfectly. This is true whether I use the HPWM command and PBP defines or set up the PWM registers directly as described in the data sheet.
    What happens is that portc.1 goes low and stays that way. If I disable the DT includes and the interrupt handler, the PWM CCP2 port functions normally. I have checked and double checked things like the portb/c multiplexing and the tris output settings, etc. What I think is happening is something in Darrrell's code is clearing CCP2CON, but I haven't been able to find it.
    Does anybody have any ideas to try?
    Thanks--
    --Alan
    Feb 2005
    Kolkata-India
    Default Can we have the code please
    It is very unlikely that DT's int handler mess with your CCP2CON register. Do you have a LCD / Serial / Debug out then try dumping the CCP2COn values periodically to know whats going on.
    A look at the code may be helpful. I have 18F4520 ready with me and would like to duplicate the problem for my own interest.
    Sougata
    Jun 2005
    Hi sougata--
    The code is massive, with a dozen include files... it would be a real mess to upload it. PWM on channel 1 always works. I have discovered since I posted that message that if I start Timer1 (T1CON.0 = 1, the timer that is used by Darrell's Elapsed Timer code), then the PWM on channel 2 works. Stop timer 1, and channel 2 PWM stops working. But if I comment out all of Darrell's code and recompile, both PWM ports work perfectly.
    PWM only uses Timer 2, so I am baffled. I do have an LCD attached, I will try reading the CCP2CON register and see what its thinking.
    Thanks--
    --Alan
    Aug 2008
    Exclamation DT_INTS breaks pulsein/count PBP routines?
    Is this true? I can believe it to be. If so, is there any way I can replace this functionality using the interrupt driven counters or something? A hardware counter is not an option unfortunately, as the board is already in units in the field.
    The reason I need to add interrupts is because I need to add background hardware UART character reception using UART2 because the program spends too much time doing other things in the foreground to service the port soon enough.
    Is there a list of what PBP functions are affected by DT_INTS? If so where can I find it?
    Does anyone have examples of interrupt driven serial IO using DT_INTS? How about pulse counting routines?
    Mike
    Mar 2006
    Pennsylvania, USA.
    Hi Mike,
    Here is my serial interrupt handler using Darrel's Instant Interrupts;
    SerialInt:
    Hserin [STR buffer\45\$8e] 'read up to 45 bytes into array, end if value is hex 8e.
    @ Int_Return
    That's all there is to it. If you do a search for frequency measurement, you will find some code that Bruce put together using Instant Interrupts to measure pulse width, and I think you could make it work for you.
    Good Luck,
    Jerry
    If your oscilloscope costs more than your car...
    Aug 2008
    Thanks for the code snippet! It looks easier then I thought it would be to implement the serial stuff. I was worried I would have to code something in ASM and use buffers etc...
    As for the frequency measurement stuff, I did a search and I can't seem to find what your referring to. Do you happen to have a link handy? Is it on this board, or somewhere else?
    Mike
    Feb 2008
    Michigan, USA
    Default Changing direction after INT
    I'm trying to understand how to return to a specific place when coming out of a INT.
    Specifically, when I receive a command serially and trip the RX_INT, I need to abort the current operation in the main body of the program and restart with the newly commanded mode.
    I have looked at DT_INTS and other advise on interrupts, and still don't understand what I would need to change to get this to happen.
    The code works otherwise and gathers the command from the serial line, its just that I have to wait for the current operation to complete for it to be recognized and acted upon.
    The main code is driving patterns on 8 LEDS with SPWM_INT and it takes 10 or 20 seconds for it to get around to the place where it looks at the new mode. This also applies when I change the mode with a switch input. I have to wait until the operation is finished to get to the part where I look for the input.
    I don't believe that I can just mess with the RetAddr variable in DT_INTS and have that work without other steps. If I have a GOTO in the ISR, then I would likely corrupt the RETURN. I could just sprinkle switch and comm checks all over the place looking for flags, but that seems mediocre. Any advise?
    Mark
    We were just talking about that last month.
    This might help.
    http://www.picbasic.co.uk/forum/showthread.php?t=10263
    Feb 2008
    Michigan, USA
    Thanks for the pointer.
    I find myself trying to be more careful about how I name threads.
    It seems that if you miss something when it comes by, it can be spotty when you try to find it again.
    I have been putting effort into a systematic method to catalog the threads that I get the most from.
    There is a wealth of info if I can get better at mining it.
    Mark
    Dec 2007
    Thumbs up 7 seg display with rs232 data input
    I was testing with darrel Taylor Instant interrups. The colaboration is fantastic. Great.
    I mount four 7 seg, 4 inches each, with common anode, and the 16f877A. The input for data is the serial input, across portc.7. I probe fist without darrel tool, using on interrupts and I see that the serial input line stop de scan for the 7 segs, because the multiplexing loss the times in this waiting for the data. Each display is activate with portd.4 to portd.7
    The circuit work fine, so, the program need tuning up.
    When I used the Darrel tool, the time for the 7 segs scan don't change with the data wait in the serian in line, including this part in the main loop. The scan for the multiplexing is in instant interrup routine. My dude, in this case, is with time multiplexing scan. I not Know what is the lines for the scan, and in this moment, i only see the scan very slow.
    I need help for to put the timer a time for correct and fast scan.
    Thanks.
    Luis Elizarraraz
    If you are using an interrupt handler to receive the serial data, then nothing else can happen until the handler is finished.
    If other things must continue operating at the same time, you either have to read the serial data 1 byte per interrupt, or have the HSERIN statement in the main loop so that it can be interrupted like everthing else.
    Sitting in the handler WAITing for the data, will not work.
    Dec 2007
    Thumbs down Slow scan for 7 seg multiplexing
    Thanks for answer me Darrel.
    The code for my application is the follow:
    'Start
    define loader_used 1
    DEFINE OSC 20 ' Define crystal as 4Mhz
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    ' ** Declare the Variables **
    LEDS Var Byte ' The amount of LEDs in the display
    O_C Var Byte ' Used by the interrupt for time sharing
    Counter Var byte ' General purpose counter
    Del Var Word ' General purpose delay loop variable
    del1 var word
    D_Number Var word ' The number to display on the LEDS
    DP Var Byte ' Position of the decimal point
    Disp_Patt Var Byte ' Pattern to output to PortC
    Num Var Byte[4] ' Array to hold each digits value
    Digit1 var Portd.4 ' 1ro
    Digit0 Var Portd.5 ' 2do
    Digit3 Var Portd.6 ' 3ro
    Digit2 Var Portd.7 ' 4to
    ' ** THE MAIN PROGRAM STARTS HERE **
    trisd=%00001111 'portd.4 a portd.7 like output
    TrisB=0 ' Make PortB and PortC outputs
    PortC=0:PortB=0 ' Clear PortB and PortC
    O_C=0 ' Clear the time share variable
    TRISB=0
    x var byte
    y var byte
    duty var byte
    canal var byte
    d var word
    v1 VAR word
    V2 VAR word
    ciclo var word
    indi var bit
    conta var byte
    INT_Handler TMR1_INT, _Multi, PBP, yes
    T1CON=$01 ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    d=0
    ciclo=0
    indi=0
    high portd.7
    high portd.6
    high portd.5
    high portd.4
    serout2 portc.6,84,[13,"C>"]
    serin2 portc.7,84,3000,main,[dec4 D_Number]
    serout2 portc.6,84,["L"]
    Gosub Display ' Display the value
    Display:
    For LEDS=3 to 0 step -1 ' Loop for 4 digits (0-65535) ' Disable the interrupt while we calculate
    Num[LEDS]=D_Number dig LEDS ' Extract the seperate digits into the array
    If D_Number<10 and LEDS=1 then Num[LEDS]=10 ' Zero Suppression for the second digit
    If D_Number<100 and LEDS=2 then Num[LEDS]=10 ' Zero Suppression for the Third digit
    If D_Number<1000 and LEDS=3 then Num[LEDS]=10 ' Zero Suppression for the Third digit ' Re-enable the interrupt
    Next
    ' INTERRUPT HANDLER
    ' Multiplexes the 3-digits
    Disable ' Disable all interupts during the interrupt handler
    Multi:
    'sigue: ' 0 1 2 3 4 5 6 7 8 9 A B C E F G H I J L N 0 U b c d e f g h i n p q s o u
    lookup Num[O_C],[63,6,91,79,102,109,125,39,127,111,119,127,57,121,1 13,125,118,6,30,56,55,63,62,124,88,94,123,113,111, 116,4,84,115,103,109,92,28],Disp_Patt
    ' Lookup Num[O_C],[192,249,164,176,153,146,130,248,128,144,255],Disp_Patt ' Decode the segments for the LED
    ' Process the first display (farthest right)
    If O_C=0 then ' If it is our turn then
    Digit3=1 ' Turn OFF the 3er LED
    PortB=Disp_Patt ' Place the digit pattern on portC
    If DP=1 then PortB.7=0 ' Check the value of DP and Turn ON the decimal point
    Digit0=0 ' Turn ON the first LED
    Endif
    ' Process the second display
    If O_C=1 then ' If it is our turn then
    Digit0=1 ' Turn OFF the first LED
    If DP=2 then PortB.7=0 ' Check the value of DP and Turn ON the decimal point
    Digit1=0 ' Turn ON the second LED
    Endif
    ' Process the third display
    If O_C=2 then ' If it is our turn then
    Digit1=1 ' Turn OFF the second LED
    If DP=3 then PortB.7=0 ' Check the value of DP and Turn ON the decimal point
    Digit2=0 ' Turn ON the third LED
    Endif
    ' Process the 4th display
    If O_C=3 then ' If it is our turn then
    Digit2=1 ' Turn OFF the second LED
    If DP=4 then PortB.7=0 ' Check the value of DP and Turn ON the decimal point
    Digit3=0 ' Turn ON the third LED
    Endif
    O_C=O_C+1 ' Increment the time share counter
    If O_C>=4 then O_C=0 ' If it reaches 3 or over then clear it
    @ INT_RETURN ' Allow more interrupts
    Yup, that's pretty slow.
    At 20mhz with 1:1 prescaler, you'll get an interrupt every 13.1ms.
    That's 52.4ms for all 4 digits, which is a 20hz refresh rate. Way too slow.
    If you want to make it go faster, you have to load something in the Timer. As it is, it's just free-running.
    Also, you'll never get those SERIN/OUT2's to work. They are timed by software, which gets continuously interrupted. You need to use the USART with HSERIN/OUT.
    And, ENABLE/DISABLE are for ON INTERRUPT. They have no effect with Instant Interrupts.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 6
