Sure you can.
I'd use the Capture mode of the CCP modules using Timer1, for the ON time.
Timer 2 can be the timebase used to count the speedometer pulses on the INT (external interrupt) pin.
And the same signal from the Injector can be fed to T0CKI, so Timer 0 can count the RPM's too.
Speed, Distance, Consumption and Tachometer.
