Instant Interrupts - Revisited
Results 1 to 40 of 773
    Jun 2007
    Thanx for your answer.
    I understand you about the understanding the code.... me too sometimes....
    OK lcdout cadena\20
    >And the reason you're missing characters, is probably because the data is >received by the interrupt handler, but it's being put into the "buffer" array in >the main loop. That should be done in the handler too.
    ¿? Something like this?:
    '---[RX - inmterrupt handler]----------------------------------------------
    Int_RX:
    PORTA.1 = 1 'to check RX int has come
    hserin [char]
    cadena[i] )= char
    i = i +1
    @ INT_RETURN
    but lcd displays rare....
    Don´t worry i´ll figth with it.
    Thanx for all.
    Better, but it still needs a way to limit it to the "bounds" of the array. Or, it will overwrite all your other variables. Maybe like this.
    Int_RX:
        hserin [cadena(i)]
        i = i +1
        if i >= 20 then i = 0
    @ INT_RETURN
    Of course this still has the problems of not knowing how many bytes were received, if the buffer overflows, if USART errored etc.
    You might want to take a look at this program from Joe S.
    LCD serial backpacks
    http://www.picbasic.co.uk/forum/showthread.php?p=28336
    It has a complete "Circular Buffer" using DT_INTS.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
