Instant Interrupts - Revisited
Results 1 to 40 of 773
    Feb 2005
    Kolkata-India
    Thumbs up Thanks Darrel
    It works. Your II rules. I am using it to 100Hz and thanks for your concern.
    Sougata
    Interrupt for 18F's works fine.
    How to write assembly to set a variable instead of toggle led?
    Norm
    '---[TMR1_INT - interrupt handler]------------------------------------------
    ToggleLED1
        btg  _LED1               ; toggle the pin
        INT_RETURN
    That depends on the type of variable, and what you want to set it too.
    INTERRUPT_SET VAR BIT
    set to 1
    Norm
    ToggleLED1
        MOVE?CT   1, _INTERRUPT_SET
        INT_RETURN
    Works good. Thank you.
    I would like to reload timer 1 on each interrupt from a variable.
    Something like:
    wTIMER1 var TMR1L      ' access 16 bits of TMR1
    wTimerPreload VAR WORD
    wTimerPreload  = 65211  'adjust in program
    ToggleLED1
        MOVE?CT   1, _INTERRUPT_SET    ; SET FLAG
        INT_RETURN
    wTIMER1 = wTimerPreload  ; in assembly
    Norm
    See this page...
    DT_INTS-14 (Timer Template)
    http://darreltaylor.com/DT_INTS-14/TimerTemplate.html
    It's in the 14-bit section, but it's pretty much the same for 18F's
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
