Instant Interrupts - Revisited
Results 1 to 40 of 773
    Question Darrels' Bring Together Interrupts
    Hello,
    I have been toying with Darrels' interrupts and the elapsed timer
    programs. It's an amazing piece of work and just what I need at the
    moment. Thanks!
    Going on, I tried the "bring together" demo but that didn't go so
    well. It won't compile using MPASM. The error messages are ;
    FATAL ERROR too many errors
    Error line 15: redefination of VAR. (DT_INTS-14.bas)
    Error line 26: redefination of VAR. (DT_INTS-14.bas)
    Error line 27: redefination of VAR. (DT_INTS-14.bas)
    ........Etc.
    I am using the Pic 16f877 but that shouldnt matter at this point.
    Any ideas?
    Thanks John
    Homerclese
    mmm, weird, no problem here. so we talk about
    http://darreltaylor.com/DT_INTS-14/combine.html
    If so, did you add something special in the code or you're using EXACTLY the following...
    LED1   VAR  PORTD.0
    LED2   VAR  PORTD.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INCLUDE "Elapsed_INT.bas"    ' Elapsed Timer Routines
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    OPTION_REG = OPTION_REG & $80 | 1  ; Set TMR0 Prescaler to 256, leave RBPU alone
    @    INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    @    INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
    @    INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    GOSUB ResetTime              ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer             ' Start the Elapsed Timer
        IF SecondsChanged = 1 THEN
           SecondsChanged = 0
           LCDOUT $FE,$C0, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    '---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
    T0Count  VAR WORD
    ToggleLED2:
        T0Count = T0Count + 1
        IF T0Count = 512 THEN T0Count = 0 : TOGGLE LED2
    @ INT_RETURN
    which version of PBP and MPASM are you using?
    Are all files located in the same folder?
    Question
    Hello,
    I tried a cut and paste of your code and got a whole new set of errors. The only code differences I could find were the ones at the top for outputting to a LCD display. The include files all exist in my usual PBP folder. I'm using Microcode Studio version 2.2.1.1 with Pic Basic Pro 2.40.
    Thanks John
    Homerclese
    did you get...
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1438&stc=1&d=117284877 8">
    If so, make sure you have selected MPASM in the View>> Compile And Program option >>> Assembler
    EDIT
    Pic Basic Pro 2.40.
    I don't know if it could be the problem... The current version is now 2.47.
    Question
    Gettin' better!
    MPASM box was not checked. I didn't know it existed. No errors on compile now, however it can not find the .HEX file for programming. I did a system search and there is no .HEX file generated after compile. There are .HXH and .HXL files.
    Is your result box a screen capture?
    Thanks again
    Homerclese
    It happen because you probably have selected INH8XS file format under the MPASM check box. use INHX8M instead.
    Yes indeed, CTRL + PrintScr, then you paste it in Paint or whatever else to edit it.
    Question
    Good, That worked. However, when I add a line to the top of the program as simple as :
    TRISA = %00000000
    AlarmOUT VAR PORTA.0
    I get
    Error[113 cbp\pbpic14.lib 1588 : Symbol not previously defined (port A)
    Error[113 cbp\pbpic14.lib 1612 : Symbol not previously defined (port A)
    Error[113 cbp\pbpic14.lib 1619 : Symbol not previously defined (port A)
    .........Etc.
    Also, going back to the previously working "elapsed timer demo" and using the MPASM settings I get the same type of errors there if I try to add a port reference.
    I can get the result box into Photoshop but can't get the edited image to paste into the forum.
    Homerclese
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
