Instant Interrupts - Revisited
Results 1 to 40 of 773
    Microchip can't make up thier mind on what they want to call things. In most 16F's it's called T0IF, and in the 18F's it's TMR0IF, but for some reason, in a 16F88 it's also called TMR0IF. It's the same with the T0IE/TMR0IE.
    Fortunately, we aren't stuck with whatever they decide to call things.
    Just add the 2 highlighted lines, and you should be fine. (no spaces before them)
    T0IF = TMR0IF
    T0IE = TMR0IE
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE   INT_INT     ; enable external (INT) interrupts
        INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
        INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    Jun 2006
    Smile
    Thank you.
    Now it's work.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
