Dear Darrel,
I just would like to let you know the combined DT_INTS-14 and SPWM_INT working fine!!
I control 5 Hi power LED’s Using 5 PWM signals (100Herz, 200 step), LED selecting is done by 3 address lines and the actual control by a pulsed STEP and a UP/DOWN level input.
STEP is causing the INT external interrupt doing the actual PWM change (controlling DutyVar1 to DutyVar5)
Whenever I change a PWM value, it’s stored as the new default in EEprom (using WRITE command with DISABLE INTERRUPT before and ENABLE INTERRUPT after, working OK too).
If you like to have more info on both hardware and software, let me know.
Thank you for your help!
Willem
