Instant Interrupts - Revisited
Results 1 to 40 of 773
Threaded View
  1. #11
    Darrel,
    How about this one? I have one interrupt to generate a USB Service, that part works fine. I'd like to add another interrupt for USB reception, is that what USB_INT is for?
    Here is a snip of code:
    ;----[High Priority Interrupts]-----------------------------------------------
    INT_LIST  macro    ; IntSource,        Label,      Type, ResetFlag?
            INT_Handler   TMR1_INT,  _ServiceUSB,    PBP,  yes
            INT_Handler   USB_INT,    _ReceiveUSB,   PBP,  yes
        INT_CREATE               ; Creates the High priority interrupt processor
    '---[USB - interrupt handler]------------------------------------------------
    ReceiveUSB:
       @ INT_DISABLE TMR1_INT   ; disable USB service interrupt
       USBBufferCount = USBBufferSizeRX
    DoUSBIn:
       USBservice ; Generate USB Service manually
       USBIn 1, USBBuffer, USBBufferCount, DoUSBIn
       varUsbIn = conByteHigh  ' Set flag data has arrived
    @ INT_ENABLE  TMR1_INT   ; enable USB Service interrupts
    @ INT_RETURN
    ServiceUSB:
        USBservice
    @ INT_RETURN
    Does that make sense? Or can I leave the USB Service interrupt enabled throughout the USB Reception interrupt?
    Last edited by Darrel Taylor; - 15th August 2006 at 08:45. Reason: added [code][/code] tags
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 6
