Darrel,
How about this one? I have one interrupt to generate a USB Service, that part works fine. I'd like to add another interrupt for USB reception, is that what USB_INT is for?
Here is a snip of code:
;----[High Priority Interrupts]-----------------------------------------------
INT_Handler TMR1_INT, _ServiceUSB, PBP, yes
INT_Handler USB_INT, _ReceiveUSB, PBP, yes
INT_CREATE ; Creates the High priority interrupt processor
'---[USB - interrupt handler]------------------------------------------------
ReceiveUSB:
@ INT_DISABLE TMR1_INT ; disable USB service interrupt
USBBufferCount = USBBufferSizeRX
DoUSBIn:
USBservice ; Generate USB Service manually
USBIn 1, USBBuffer, USBBufferCount, DoUSBIn
varUsbIn = conByteHigh ' Set flag data has arrived
@ INT_ENABLE TMR1_INT ; enable USB Service interrupts
@ INT_RETURN
ServiceUSB:
USBservice
@ INT_RETURN
Does that make sense? Or can I leave the USB Service interrupt enabled throughout the USB Reception interrupt?
