Ok, I added the disable/enable at both assembler USB routines generated from HIDMaker but the device is not recognized. I rummaged through the datasheet for TMR1 and T1CON and found this:
When Timer1 is enabled, the RC1/T1OSI/UOE and
RC0/T1OSO/T13CKI pins become inputs. This means
the values of TRISC<1:0> are ignored and the pins are
read as ‘0’.
Now that sucks, I'm using those pins as output to a LCD. I expected the LCD to spaz out but it's working fine.
I had started with an 18F4550 QFP but had downgraded to a 18F2550 SOIC, easier to solder. I don't have any output pins to spare either, the only pin I'm not using is A3.
I hate to have to yank all this off the breadboard to put back the 18F4550, again, but I might not have any choice.
I think I'm going to comment out all unnecessary code (interrupts/HSERIN/HSEROUT) until I have a working USB program again (sprinkling USBSERVICE everywhere). Then I'll put the USB interrupt back in and go on from there.
