Instant Interrupts - Revisited
Results 1 to 40 of 773
    Jul 2008
    TURKIYE-KONYA
    Default Re: Instant Interrupts - Revisited
    Quote Originally Posted by LinkMTech View Post
    I tried your INT code mod and sample code here (added Counter VAR Word) and it compiled okay.
    A couple questions:
    What are you try to do that is not happening?
    And excuse my ignorance, but what is ISIS?
    * There is no problem with compiling. It's okay.
    * There are buttons tied PORTA.0, PORTA.1, PORTA.2 - PORTB.4 and PORTB.6. I want to get interrupt every logic change on this ports. If you look at IOCA and IOCB registers, these ports are enabled for interrupt.
    * ISIS is a simulation program.
    DT_INTS does not clear the ioc int flag you need to do that yourself either in your isr or when you ready to rearm the interrupt
    I'm wrong there, I was thinking of ioca/b int issues I had some years back . but after having another look it was with a 16f1825 which has an individual ioc flag for every ioc pin , but it won't hurt to rule that out anyway
    Jul 2008
    TURKIYE-KONYA
    Hello everyone..
    I read this post today. And added MOVF PORTA, W - MOVF PORTB, W. Now it's working as it should be.
    RABC :
    @ MOVF PORTA, W
    @ MOVF PORTB, W
        COUNTER = COUNTER + 1
    @ INT_RETURN
    Feb 2010
    Hello,
    i have a working code which uses
    CMP_INT and TMR1_INT.
    I want when TMR1_INT event triggered ,
    to change the period (or Frequency as entered) and reload the TMR1 with a new value.
    Is this possible to put mutiple instances of e.g.
    @Freq = 416 ; Frequency of Interrupts in Hz 416Hz
    Thank you.
    Is this possible to put mutiple instances of e.g. @Freq = 416
    "Freq " would be a label and cannot be redefined
    you can however
    @Freq1 = 416
    @Freq2 = 410
    @Freq3 = 466
    if you need to change the tmr1 interrupt rate the tmr1 reload value needs to be a var
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 4
