Instant Interrupts - Revisited
Results 1 to 40 of 773
    Jul 2008
    TURKIYE-KONYA
    Default Re: Instant Interrupts - Revisited
    I'm working on a project using 18LF13K22. I need to use RAB Change Interrupt with DT Ints18. I made changes on DT_INTS-18.bas below but i couldn't succeed. Any suggestion?
    #define RABC_INT  INTCON, RABIF   ;-- RAB Port Change
    ifdef RABIF
          INT_Source  INTCON,RABIF, INTCON, RABIE,INTCON2,RABIP
    Thanks..
    Nov 2007
    West Covina, CA
    I had to do the same thing with the PIC18F14K50.
    Our entries look similar except your label is RABC_INT.
    #define RAB_INT   INTCON, RABIF   ;-- RAB Port Change, Added 3/15/14 for PIC18F14K50
    and
      ifdef RABIF    ;----{ RAB Port Change Interrupt }-----------[INTCON, RABIF]--- (Added 3/15/14 for PIC18F14K50
          INT_Source  INTCON,RABIF, INTCON,RABIE, INTCON2,RABIP
    Could it be you're not enabling it with:
    INT_ENABLE  RABC_INT   ; Enable IOC
    Louie
    Nov 2007
    West Covina, CA
    Edit: ooops, forgot the "@".
    @ INT_ENABLE  RABC_INT   ; Enable IOC
    Louie
    Jul 2008
    TURKIYE-KONYA
    Quote Originally Posted by LinkMTech View Post
    and
    Thanks for your reply. I tried to work it with ISIS. It may cause for it. I'm waiting for chips. I will try it again.
    Jul 2008
    TURKIYE-KONYA
    The chips have arrived. I tried RAB change interrupt on a demo board. The situation is the same with isis. This is my test code below.
        INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
        OSCCON  = %00110100
        OSCCON2 = 0
        OSCTUNE = %10000000
        TRISA   = %11101111
        TRISB   = %11111111
        TRISC   = %00000000
        ANSEL   = 0
        ANSELH  = 0
        INTCON2.7   = 0
        WPUA        = %00101111
        WPUB        = %11110000
        IOCA        = %00000111
        IOCB        = %01010000
    INT_LIST  macro    ; IntSource,      Label,  Type, ResetFlag?
                        INT_Handler   RABC_INT,  _RABC,   PBP,  yes
        INT_ENABLE  RABC_INT
        MAIN:
    GOTO MAIN
         RABC :
        COUNTER = COUNTER + 1
    @ INT_RETURN
    Nov 2007
    West Covina, CA
    I tried your INT code mod and sample code here (added Counter VAR Word) and it compiled okay.
    A couple questions:
    What are you try to do that is not happening?
    And excuse my ignorance, but what is ISIS?
    Louie
    but what is ISIS?
    looks like an Egyptian goddess
    https://en.wikipedia.org/wiki/Isis
    but it probably this
    http:/'s/www.picmicros.org.uk/Interfacing/TUTORIAL.htm
    Jul 2008
    TURKIYE-KONYA
    A couple questions:
    * There is no problem with compiling. It's okay.
    * There are buttons tied PORTA.0, PORTA.1, PORTA.2 - PORTB.4 and PORTB.6. I want to get interrupt every logic change on this ports. If you look at IOCA and IOCB registers, these ports are enabled for interrupt.
    * ISIS is a simulation program.
    DT_INTS does not clear the ioc int flag you need to do that yourself either in your isr or when you ready to rearm the interrupt
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
