You'll need to post ALL the code before folks can help I think, since the problem is not necessarily in this little bit. The "@ INT_RETURN" suggests these are the actual interrupt routines? One thing to be cautious about is that interrupts can occur while you are in your handler routine, causing the routine to restart and all sorts of other strange problems. Your interrupt routine should be as fast as possible - usually only a flag is set, that your main program loop can quickly detect and take action on. If you must do a few things in the routine, then you need to disable interrupts while in the routine, and risk missing something.
