Instant Interrupts - Revisited
Results 1 to 40 of 773
    Default Re: Instant Interrupts - Revisited
    Damir,
    I can duplicate the issue here, which appears to be the old R-M-W hardware problem.
    I moved the PWMs over to PORTC, and everything works fine.
    Since I2C uses pull-ups instead of bi-polar driven outputs, it's more susceptable to R-M-W problems.
    If you cannot move pins around on your project, you can get away with the following.
    In general, I do not recommend doing this type of modification.
    But in your specific case, it should work.
      SPWM_LIST macro
          SPWM_PIN LATA, 2, _CH1
          SPWM_PIN LATA, 3, _CH2
          SPWM_PIN LATA, 4, _CH3
          SPWM_PIN LATA, 5, _CH4
    I should have also mentioned that when using the LATA register, you'll need to set the pins to output manually.
    TRISA = %11000011
    May 2012
    Thank you very much!
    I must add TRISA = 0 to the begin of code, and then start work great.
    One more time, thank you, Damir.
    May 2006
    Del Rio, TX, USA
    Darrel,
    While poking around and getting ideas, I got to looking at ver 1.2 of "Elapsed_INT-18.bas". I was particularly interested in the nice routine to calculate the timer reload constant:
    ' -------------- calc timer reload Constants -------------------------------
    T1PS = 1                             ; start with 1:1 postscaler
    TimerConst = ((OSC*1000000)/4/100)   ; how many timer ticks will it take
      while TimerConst > 65400           ; if it's more than the timer can count
    T1PS = T1PS * 2                      ;   double the postscaler
    TimerConst = TimerConst / 2          ;   halve the count
      endw
    TimerConst = 65536 - TimerConst + 8  ; final reload value
    But, I think there is an error in the formula. The absolute time it takes to execute the 8 instruction cycles doesn’t change. But, the time in relation to the TMR1L will be proportional to the prescaler. So, that should be accounted for in the formula, as such:
    TimerConst = 65536 - TimerConst + (8/T1PS)  ; final reload value
    Since it's not likely the prescaler will need to be above 1:8, the 8/T1PS shouldn’t get too low.
    Thanks again for your great work and inspiring examples,
    May 2006
    Del Rio, TX, USA
    The code could also be changed thus, not that it makes a difference:
    TimerConst = ((OSC*1000000)/4/100)+8 ; how many timer ticks will it take
      endw
    TimerConst = 65536 - TimerConst      ; final reload value
    Aug 2005
    Hi Darryl,
    Currently getting an error with Latest MPLAB IDE:
    MPLAB 8.90.00.00
    PIC is an 18F45K22 and DT_INTS-18 is latest from your website, both MPLAM and DT_INTS were downloaded from the respective sites on 15/3/2013
    ERROR: Unable to execute mpasmwin.Warning[206] M:\<FOLDERPATH><FILE>ASM 2170 : Found call to macro in column 1. (INT_ENABLE)
    Error[116] M:\<FOLDERPATH><FILE>.ASM 696 : Address label duplicated or different in second pass (Z00032)
    Error[116] M:\<FOLDERPATH><FILE>.ASM 759 : Address label duplicated or different in second pass (Z00033)
    Error[116] M:\<FOLDERPATH><FILE>.ASM 812 : Address label duplicated or different in second pass (Z00034)
    Error[116] M:\<FOLDERPATH><FILE>.ASM 843 : Address label duplicated or different in second pass (Z00035)
    Can you advise if there is any fix for this or do i need to use an older version of MPLAB IDE
    New Jersey
    I've used the DT_INTS sucessfully with an 18F4550. I had to move to an 18F87J50 but the DT_INTS would not compile. Not sure if I'm doing something wrong or if the DT_INTS was never tested with J series PIC's. When I compile, I get the following warning message:
    Unable to fit variable VP_DelayCount in requested bank 0
    In the "VirtualPort.bas" code, I changed this code:
    VP_DelayCount  VAR WORD BANK0  ; Used for internal Delay only
    to this:
    VP_DelayCount  VAR WORD BANK1  ; Used for internal Delay only
    and it compiled as expected. I have no clue if this will cause unexpected problems with my program or if this is the correct way to solve it but I haven't noticed any ill effects yet. Seems like this problem could be related to the SFR's but it's way above my level of knowledge.
    Just thought I'd pass it along.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 6
