Instant Interrupts - Revisited
Results 1 to 40 of 773
    Sep 2010
    Las Vegas, NV
    Default Re: Instant Interrupts - Revisited
    If this topic was previously mentioned, I apologize for not finding it.
    I'm using a 16F877A with a 4 MHz crystal and two 22pf caps with a LED hooked up to portb.1 and the code from example 2 of DT_ints-14.bas on DTs site. I'm using a oscope to look at the timing of the LED flashes and they are occuring around 950msec apart.
    My question is, is there a way to tune the oscillator or modify DT interrupts to get it closer to a true 1 second pulse time? I know it's not far off but I was trying to learn something and maybe make it more accurate at the same time. Your help would be appreciated.
    Yes I did read the datasheet but I couldn't find anything like OSC tune that I've seen for the 12F683.
    Feb 2005
    Kolkata-India
    When using multiple interrupt sources you can prioritize which Interrupt flags to check when vectored to ISR, still the results may not be deterministic every time. Say you are already servicing a lower priority interrupt (not Hardware but DT's scheme) a higher priority interrupt like your time tick occurs. Generally adding the rolling timer with the offset value does the trick however if you would like more precision then use the compare module on the PIC which resets the associated timer automatically and gives a rock solid time base.
    Sougata
    You need to fine tune the timer, not the OSC.
    Here is an example
    http://www.picbasic.co.uk/forum/show...3259#post23259
    And here is another
    http://www.picbasic.co.uk/forum/show...5912#post75912
    And this will help with the calcs.
    http://www.picbasic.co.uk/forum/cont....-PICMultiCalc
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
