Instant Interrupts - Revisited
Results 1 to 40 of 773
    Default Re: Instant Interrupts - Revisited
    Darrel has changed the way DT-INTs work now.
    It may surprise but is far better now.
    Happy burning
    Mar 2011
    Just so I don't miss anything, can you direct me to more information on how they have changed? Is that on line?
    For the practical side, users just get a descriptive message as of what to do in the main program. This errors,that are instructions really, may scare a little. But they just tell you what to do.
    Regarding the setup there is no change for the users.
    Mar 2011
    Thanks for taking the time to point this out for me.
    Like many things, it seems obvious now that you say it, and I get to slap myself on the forehead again.
    It's working fine.
    Nov 2008
    Hi Darrel,
    i found a problem which is not clear to me:
    I hava a 18(L)F25K22 and want to use SSP1_INT for my I2C handler, but after compiling the source, i get this error:
    ....test.asm 1052 : Symbol not priveiously defined (SSP1IF)
    When defining SSP2_INT there is no error.
    Ralf
    Ralf,
    What version of MPLAB are you using?
    I don't get the error when compiling for SSP1_INT here.
    When dealing with new chips like the 25K22, you should always keep up to date.
    Current MPLAB version is 8.66.
    http://www.microchip.com/stellent/id...&part=SW007002
    Nov 2008
    Hi Darrel,
    yes you are right, i had 8.56, now 8.66 and it works.
    BTW: For all I2C Slave progger:
    To get the I2C Slave running on a 25K22, use SSP1_INT or SSP2_Int, and, very important, you must set ANSC4 & ANSC3 = 0 for SSP1 and ANSB1 & ANSB0 = 0.
    Ralf
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
