Instant Interrupts - Revisited
Results 1 to 40 of 773
    Aug 2010
    Maryland, USA
    Default Re: Instant Interrupts - Revisited
    Really? Who makes the ESC? On the other hand, I doubt you will notice a difference, but hey go for it!!
    -Bert
    Aug 2011
    It is a Castle Creations ESC........when I spoke to one of their engineers they said all of their ESCs have 2048+ speed steps. I know I can get away with the 8 bit resolution of a standard ESC......but as an engineer I need to get the best (i.e. overkill!) solution!
    Aug 2010
    Maryland, USA
    The part I can't get through my thick head is this, how small of a change can we cause to happen in 20mS to a spinning mass? So if the motor were actually spinning 20,000, then thats 9.75 rpm per bit at 11 bit resolution. On the other hand, getting the extra bit from the PIC may cause less time available to do other things. Mind you I have never looked at PWPS.
    -Bert
    Hi. I am trying to make this Rotary Encoder work with DT-INTS on a 16F1827 device.
    It gets once in the interrupt routine and never seem to exit.
    Here is the code so far driving me crazy.
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_ON & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _LVP_OFF & _STVREN_OFF & _BORV_25
    DEFINE OSC 32
    OSCCON= %11110000   'PLL enabled, Internal RC-8MHz
    ' Set LCD Data port
    DEFINE LCD_DREG PORTA
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 3
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    'Initializing Registers
      PORTB = 0:PORTA = 0
      TRISB = $33
      TRISA = 0
      ADCON0 = 0
      ADCON1 = 0
      ANSELA = 0
      ANSELB = 0
      INTCON = $88 ' Binary 10001000
      IOCBP=$30
      IOCBN=$30
      OPTION_REG = 0
      WPUB=$33
    eeprom 0,[2,0,3,1,1,3,0,2]
    led       var portb.4
    Flag      var bit
    wsave     VAR BYTE    $70     SYSTEM  ' alternate save location for W
    Q_New     var Byte
    Q_Old     var byte
    M_Count   var byte [4]
    P_Count   var byte [4]
    Q_Count   var word
    temp      var byte
    clear
    For Q_Old = 0 to 3
    Read Q_Old,M_Count[Q_Old]
    Read Q_Old + 4,P_Count[Q_Old]
    Next Q_Old
      Q_Count = 0
        Q_New = 0
        Q_Old = 0
         Flag = 0
    INT_LIST  macro    ; IntSource,        Label,  Type,  Resetflag?
            INT_Handler    IOC_INT,      _Encoder,  pbp,     yes
        INT_CREATE                   ; Creates the interrupt processor
    @ INT_ENABLE IOC_INT            ; enable external (INT) interrupts
    '---------------------------- Initialize LCD ----------------------------
    Lcdout $fe, 1                               ' Clear LCD screen
    Lcdout "System Ready"                       ' Display message
    Pause 500                                   ' Wait .5 second
    Q_Count=50
    Goto Main_Loop
    Encoder:                                    ' ISR
        Q_New = PortB.5 + PortB.5 + PortB.4         ' get port status
        If M_Count[Q_Old] = Q_New then              ' if M_Count code satisfied then minus
                  temp=temp+1
                  if temp=4 then
                    temp=0
                    Q_Count = Q_Count - 1
                    Flag = 1                       ' set flag to true to update display
        goto Q_Skip
        If P_Count[Q_Old] = Q_New then              ' if M_Count code satisfied then plus
                  temp=temp+1
                  if temp=4 then
                    temp=0
                    Q_Count = Q_Count + 1
                    Flag = 1
                  endif                       ' set flag to true to update display
    Q_Skip:
        Q_Old = Q_New
        toggle portb.6                               ' update Q_Old Byte
    @ INT_RETURN
    Main_Loop:
    if Flag = 1 then
        Lcdout dec Q_Count                         ' Display encoder position (counts)
        Flag = 0                                   ' reset flag to false, display updated
    goto Main_Loop
    Ioannis,
    On those chips, the IOCIF bit is read-only and only gets cleared when ALL of the IOCBF flags are clear.
    So you can set the INT_Handler's ResetFlag option to NO.
    Then be sure the IOCBF flags are cleared before exiting the ISR.
    Also, take a look at section 13.4 in the datasheet regarding clearing the flags.
    Excellent! Works terrific now.
    These chips are a little pain in setting them.
    Thanks Darrel.
    May 2008
    Italy
    Use the code in post#27, (new approch to rotary encoder) is more efficient and you can achieve even higher frequency.
    Cheers
    Al.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
