Instant Interrupts - Revisited - Page 16
Results 601 to 640 of 773
Threaded View
  1. #11
    Mar 2009
    Quote Originally Posted by mark_s View Post
    Hank,
    I need to wire up a variable phase shifter, so that I can compare my results with yours. Not sure why you can't read below 33 deg? Maybe phase locking between the two comparators or interupt house keeping? What happens if you halve the frequency?
    It all works well above a certain phase shift (depending on the signal frequency)...just when you get to the lower regions that this quirk kicks in.
    I'm sure you're sorted for a phase shift cct, there's a simple one here....
    http://www.werewoolf.org.je/graphics/apf1.gif
    ....make R1 & R2 the same value -I used 10k - the cap about 100nf & R4 a 10k pot (wired with the wiper to the ground end)....this gives about 90 degrees of phase shift @ 159Hz...if you want more phase shift,cascade a few together & use this designer http://www.aleph.co.jp/~takeda/radio/psDesigner.swf
    just be sure that the signals into your PIC comparator are identical (I square them up first - remember ...different edge 'slopes' equals different triggering points for the PIC comparators which translates into a phase measurement error - and I also check on a scope to make sure there aren't any edge timing errors intrduced prior to the PIC)
    If I half the incoming frequency (or double it), the Comp2 count remains the same (ie it won't go below 336, as I phase shift to the lower regions)...so I'm inclined to think it's housekeeping 'can't avoid' timing issue of some sort.
    there maybe one fly in my particular ointment - my PIC supply is 4V...the datasheet says that 4.5V is the minimum when using a 20Mhz External clock. (& annoyingly, I don't appear have any 5V regulators handy so now looking at dropping the clock back to 8Mhz)
    I look forward to your results so get a move on!
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
