Instant Interrupts - Revisited
Results 1 to 40 of 773
    Hi Bob.
    I think you must be very quick on the 4th button to exit (less that 250ms plus the debug delay). If you hold the button longer the ISR will activate again,won't it?
    Also the:
    @ INT_CLEAR RBC_INT
    @ INT_ENABLE RBC_INT
    at the end of the ISR are not necessary as they are handled by the DT_Ints, right?
    Jan 2010
    PHILADELPHIA, PA - USA
    Ioannis...You're right about this. the 250 mS delay is fine on the simulator, but is a little too short to be reliable with real hardware buttons. 400-600 is a better number for use on the hardware.
    Also the:
    @ INT_CLEAR RBC_INT
    Thanks for pointing this out...it seems to be somewhat dependent on the value of the DT_INT ResetFlag Here's what I found:
    Disabling @ INT_CLEAR RBC_INT
    ResetFlag = yes - no change to program operation
    ResetFlag = no - Interrupt reactivates again immediately
    So the @ INT_CLEAR RBC_INT is dependent on the ResetFlag setting
    Disabling @ INT_ENABLE RBC_INT
    ResetFlag = no - no change to program operation
    So the @ INT_ENABLE RBC_INT is not necessary.
    I also now realize that I still haven't quite figured out the how INT_DISABLE RBC_INT effects the Interrupt handler in it's different states.
    Bob W.
    Wozzy-2010
    Why do you care so much about Enable/Disable flags? All these are taken care by Darrel in his routines, so normally you don't have to deal with them.
    Just do as his examples show and you are OK.
    In the extreme case you want some control as to when the interrupts are re-enabled, just use the @INT_ENABLE or @INT_DISABLE commands locally.
    Also the simplistic debouncing of a button with time delay is not very elegant and is not recommended as it can delay the program execution.
    Jan 2010
    Ioannis,
    I'm really just trying to fully understand this particular interrupt. It's a good learning exercise for me before I go on to other interrupts. I am learning that Darrel's routines are actually much easier to use and sensible than I thought, before I thoroughly confused myself by looking at it in this much detail.
    As I'm really pretty new to this, I'd be very interested to know what is your recommendation for debouncing. Are you talking about a hardware, or a software solution?
    For my current application, the interrupt is just used to jump out of the main program to enter a set up menu. So the main program is on hold and nothing is time critical. This whole RBC_INT study is just a tangent that I went off on, when I didn't understand why the stuff that I had cut & paste from the examples didn't behave as I expected.
    Thanks again,
    Bob W.
    Wozzy-2010
    Well, the idea is to use the interrupts, both with Port Interrupt on Change and Timer.
    On the first interrupt from your button, you start the timer. If you have multiple interrupts from the same button and the timer stil runs, just drop them.
    If the timer interrupt occurs, and the button is still pressed, then you can confirm that is really pressed, setting a flag.
    Hope this helps a little.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
