Instant Interrupts - Revisited - Page 10
Results 361 to 400 of 773
Threaded View
  1. #14
    Mar 2006
    China
    Default Use T?CKI
    If you have a T?CKI pin on your pic you can use that pin to check for black stripes. This is the pin for the external clock signal connected to the internal timer/counter. This way you can get an interupt every black stripe or every 2:nd or once per wheel rotation (or anything else more or less). This is all depending of what you preload the counter with. If you have a 8-bit counter and load FF into it, next clock pulse will overflow the counter and you will get an interupt. If you preload it with FF-(dec 48) it will overflow once every full rotation of the wheel.
    If you just want to count the stripes preload it with 0 and off you go....
    This way your PIC will do most of the counting by itself and giving you more instruction time for something more useful.
    If you use the RA2/INT for the magnetic switch you can use RA5/T1CKI the external clock input for the stripes phototransistor
    /me
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
