Hi, Leonardo
Just copiying and pasting Steve's code gives ( lower left ) the following message :
SUCCESS - 366 WORDS USED
So, I think the problem is in your computer ...
Hi, Leonardo
probable cause.. there's 2 KeyPad.bas files opened in your editor as per your picture. It must be a MCS error... this 'feature' is not available in the MCSP version as i can't do it here... sorry.
Hello,
That version of PBP is using?.
Leonard
Originally Posted by mister_e
Hello Acetronis,
It can place an image of the code when it compiles it, the truth not you that to make since has the it finishes version of the PBP.
Greetings
Originally Posted by Acetronics
Originally Posted by Leonardo
Sorry, Leonardo
I do not understand anything in your sentence ... try to be a bit more explicit.
I opened Twice "keypad.bas" ... it compiles also ...
may also be Too many files opened ???
i use PBP V2.46 but it should work with most previous one. MPASM version shouldn't be much of a problem.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=938&stc=1&d=1151334864 ">
Be sure the INCLUDE file is in the same directory of your project and it should compile as is. Unless add the path in the INCLUDE line.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=939&stc=1&d=1151335131 ">
