Matrix Keypad routine
Results 1 to 40 of 135
    Oct 2008
    thats my point. I have no idea where to begin...i was thinking maybe scan keypad first, check if A or B was pressed and if so then act upon it by prompting the user to enter a desired setpoint. once that's done, press ok and return to the main display screen. the alarm can be set on for the desired lower setpoint and once the upper setpoint has been reached, the relay should switch on. vice versa
    Quote Originally Posted by Kalind View Post
    Then write some code and see how it works!
    If it doesn't work, post the code, and I'm sure somebody will help you figure it out.
    The first thing to do is open Mr. E's Keypad.bas and read the instructions he wrote for you.
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 22:58
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
  3. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 21:25
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 03:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 21:33
