Matrix Keypad routine
Results 1 to 40 of 135
    I think that's for a standard 10 TTL loads.
    But a PIC pin is only 1 load. So you can be fine with 40K, which is somewhere around the range of the internal weak pull-ups.
    Omaha, Nebraska USA
    I'm sure you're correct, Darrel. As I wrote, that was a long time ago. My feeble point was, I still automatically use that thumb rule and those values and the circuits still work. (Probably kind of like driving a tack with a sledgehammer . . . )
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Or shooting Quail with a Deer slug.
    But keep in mind we're talking keypads here.
    For something like high speed communication with I2C, lower values are required to overcome any capacitance that might cause a Slew Rate.
    In which case 4.7K is the perfect value.
    I'd say, just keep doing what you're doing, and you should be fine.
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  3. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 22:25
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 22:33
