Need advise on PIC controlling a variable resistor
Results 1 to 8 of 8
    MikeTamu's Avatar
    MikeTamu Guest
    Look into using Pulse Width Modulation if your voltage range is 0 to 5 Volts. Or you could even modulate a transistor with a higher voltage at the collector. Your PIC might have a built in PWM generator and if so, you can easily control the duty cycle to give you changeable output analog voltage abilities.
    Wink servo drive ???
    Hi, Baldwicks
    if your tone steps are not too short in time ... you could use an ALPS motorized pot ( see i.e. www.selectronic.fr ref 50.6278 as an example ) and a PIC to control the output freq and then correct the pot as desired. A kind of servo motor ... driven to give freq instead of position.
    you could then also keep manual drive of the freq ...
    Feb 2005
    Kolkata-India
    Lightbulb If its a VCO you can try a different approach
    If you are using a VCO then you might use a few more pins on the PIC to shift the voltage level on both ends of the POT. Your options are high = 5 volts, low = 0 volts and input = HighZ.
    In this way you would increase the resolution of the whole thing.So your software would control the voltage ranges between say,
    0v to 1v
    1v to 2v
    3v to 4v
    4v to 5v
    and you get 256 steps on each. Since it is a self oscillator you can feed the osillator signal back to the PIC and make a dynamic calibration routine for drifts in your ladder DA circuit + POT.
    Wishing a speedy recovery to our forum member steve who is hurt in a car accident.
    Best Regards
    Sougata
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  3. Replies: 67
    Last Post: - 8th December 2009, 03:27
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 14:16
