LookDown2 question
Results 1 to 9 of 9
    Jun 2005
    Wisconsin
    Default LookDown2 question
    In the first example var=1. In the second example var=0. I don't understand why the table isn't being search when I use variables. Thoughts?
    This works:
    Value=$5C
    LookDown2 Value,[$FF,$5C,$41],Var
    This doesn't:
    Zero=$FF
    First=$5C
    Second=$41
    Value=$5C
    LookDown2 Value,[Zero,First,Second],var
    Jun 2005
    Wisconsin
    *bump*
    Sorry I really need some resolution on this issue.
    Mar 2005
    Iowa, USA
    Post
    In your first example, var = 1 is correct, since it is the second value in the list. As for the second example, I've got to assume that var = 0 since "$5C" is not in the list and var is already 0? The manual says if the search value is not found, then var is unchanged. Have you tried setting var to a known value then run through the second example and see if it changes? Just an idea. Good luck!
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Jun 2005
    Wisconsin
    I think the issue is that you can't use a variable as a value.
    The manual reads as follows:
    "Array variables with a variable index may not be used in LOOKDOWN2 although array variables with a constant index are allowed."
    To me this means you can't do B0[1] but you can do B0. I'm I thinking wrong?
    Any help is appricated. Basically I have a list of 7 values in EEProm I need to compare to a calculated variable.
    Basically the functionality of LookDown with EEProm variable in the list.
    Mar 2005
    Iowa, USA
    Post
    The first example in the manual uses a variable in the value list.
    LOOKDOWN2 W0,[512,W1,1024],B0
    My question is will it work if your values in the list are constants?
    Ryan Miller
    Jun 2005
    Wisconsin
    I will try constants and post my results.
    Mar 2005
    Iowa, USA
    Question
    Had any luck?
    Ryan Miller
    Jun 2005
    Wisconsin
    I have not tested the theroy yet.
    I'm currently trying to iron out some ICSP issues. I will post once I have some resolution.
    Jun 2005
    Wisconsin
    I sent my question over the MELAB. Both examples worked properly for him. I guess I have problems elsewhere. I will keep searching.
  1. Timer0 Instant Interrupts Question
    By wmarchewka in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 05:29
  2. Lookup2 & Lookdown2
    By saladlee in forum Serial
    Last Post: - 4th February 2008, 20:41
  3. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:39
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
