What are the downsides of a higher frequency PIC ?
Results 1 to 3 of 3
    Brussels, Belgium
    Default What are the downsides of a higher frequency PIC ?
    Another newbie question: what is the flip side of say a 20MHz vs the standard (?) 4MHz ? Is the power consumption higher ? I guess you need PBP to make timing easier ?
    Thanks, Andrew
    Yeah, power consumption is going to be higher, but that's only a problem if you're application is battery powered. There may be some EMC issues too, but I doubt it. 20MHz is still a pretty low frequency.
    Generally speaking though, if you don't need the speed, you may as well stick with a 4MHz crystal.
    Cheers.
    ---> picnaut
    Brussels, Belgium
    Quote Originally Posted by picnaut
    Cheers.
    Yup, battery powered so I want to conserve power. Thanks, Andrew
  1. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  2. PIC sinking voltages higher that Vdd???
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 27th February 2007, 20:39
  3. Replies: 3
    Last Post: - 29th October 2006, 10:16
  4. Serial Pic to Pic using HSER
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 07:20
