This is probably quite simple
Results 1 to 12 of 12
    You've not specified what PIC you're using... so, go look in the Datasheet for your PIC... it's usually a setting of the Config Word and that information can be found in the "Special Features of the CPU" section of the Datasheet. When you program your PIC, it should appear as one of the options you can manually switch ON or OFF.
    tbriggs's Avatar
    tbriggs Guest
    Smile Watchdog timer on PIC18F452
    Sorry about that....I am using the PIC18F452 that came with the PICDEM2 board.
    I started poking around in some of the files and came across "_WDT_OFF_2H" in a "__config" statement. That solved my problem.
    Thanks for the help!
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 11:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  5. Replies: 4
    Last Post: - 7th September 2005, 15:11
