This is probably quite simple
Results 1 to 12 of 12
    Jan 2006
    New Hampshire, USA
    I tried the pause loop and the stop command but both leave the oscillator running and the current draw is 800 microamps. I tried sleep $FFF with the watchdog timer turned off;this stops the oscillator and, after a few minutes, it settles down to 40 microamps current draw which is quite acceptable.
    >I tried the pause loop and the stop command but both leave the oscillator running and the current draw is...
    Yes, but getting the current down is moot because if you look at your logical flow when you get your hardware sorted out the PIC will switch itself off before you get to the STOP point... it's only until then you need a way of stopping you code, thereafter, if everything is working as it should, you'll never get to that point (well in reality you will but the PSU would be in the throws of shutting down anyway).
    tbriggs's Avatar
    tbriggs Guest
    Question Disable watchdog timer
    How do you disable the watchdog timer in picbasic? I am trying to step through a program with the ICD2 and I keep getting the error that you can't debug with the watchdog timer enabled.
    You've not specified what PIC you're using... so, go look in the Datasheet for your PIC... it's usually a setting of the Config Word and that information can be found in the "Special Features of the CPU" section of the Datasheet. When you program your PIC, it should appear as one of the options you can manually switch ON or OFF.
    tbriggs's Avatar
    tbriggs Guest
    Smile Watchdog timer on PIC18F452
    Sorry about that....I am using the PIC18F452 that came with the PICDEM2 board.
    I started poking around in some of the files and came across "_WDT_OFF_2H" in a "__config" statement. That solved my problem.
    Thanks for the help!
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  4. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  5. Replies: 4
    Last Post: - 7th September 2005, 14:11
