This is probably quite simple
Results 1 to 12 of 12
    Jan 2006
    New Hampshire, USA
    Thanks, I erased the 16F627A and reprogrammed without the POKE statement. Now it goes around the loop for several minutes before pausing for about 1 minute, then goes around the loop again. Have you any idea why it pauses?
    The compiler (or programmer) must be putting in a default configuration. How do I know what that is, and how do I change it?
    I'm not sure why it would ever pause that long, but first read this on setting config fuses, make sure you're getting it setup like you want, then see what happens when you run your example.
    Config fuse article: http://www.picbasic.co.uk/forum/showthread.php?t=543
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    New Hampshire, USA
    Please see the program listing below. Now the problem is that the program re-executes even tho it is not supposed to. When power is applied, the oscillator starts and the program executes as it is supposed to. At the end, the oscillator stops for about 30 seconds, then starts again. I turned the Watchdog timer off thinking that would prevent it from starting again, but that did not work. If I wait long enuf, the program will re-execute and the process repeats (except the oscillator does not stop) as long as the power is left on. When I remove power and re-apply, the oscillator stops; the chip is dead. If I leave power off over night and try again, it will work again. All three port outputs are connected to LEDs. Eventually I will use port4 to turn the power off which will prevent this problem, but I would like to know why it works this way. Evidently, either the program, assembler, or IC is flaky. Or maybe it is the fact that I am using a breadboard?
    @ DEVICE WDT_OFF
    LED VAR BYTE
    PORTB = %00000000
    TRISB = %1101100
    PORTB.4 = 1 'enable V reg
    pause 3000 'wait 3 seconds
    for LED = 1 to 5
    PORTB.0 = 1
    PAUSE 63 'turn on LEDs for 63 milliseconds
    PORTB.0 = 0
    pause 63 'turn off LEDs for 63 milliseconds
    next LED
    PORTB.1 = 1
    PAUSE 5000 'turn on sound for 5 seconds
    PORTB.1 = 0
    PORTB.4 = 0 ' TURN OFF POWER
    It's just plain bad practice to stop your code dead like that with an end statement... The end statement is there to tell the compiler there's no more code to compile, NOT to tell the processor to stop!
    If you want to end execution, send the device into an endless loop...
    deadloop:
    goto deadloop ' loop till doomsday
    If you examine what's happening in your PIC, the program counter keeps incrementing and your PIC will keep on executing whatever code is remenant in the PIC. When you program a PIC, unless you specify otherwise, your PIC will not first be erased, all that happens is your new code replaces what was there previously. If your new code is smaller than what was previously in memory, then some of the previous content will remain and once your code executes, it will happilly continue into whatever garbage was there previously. You must therefore terminate your program logically. Most if not all programs are continuous loops. If your application demands a 'once-only' execution, you must program-in a suitable termination. Even if your PIC has first been erased, the PIC will continue with NOP statements untill it reaches the end of program codespace at which point what it will do will be unpredictable... it might restart, it might not, but it sure as hell will be unstable.
    Oh... and the reason I put a PAUSE statement in is that PICBasic will insert code to keep the watchdog timer happy. If you just had...
    deadloop:
    goto deadloop
    then the Watchdog (if enabled) will time out and restart the PIC as PICBasic would not had inserted a CLRWDT in that instance.
    ...or of course use PICBasics STOP statement!
    you example expanded...
    PORTB.1 = 0
    STOP
    Jan 2006
    New Hampshire, USA
    Thanks much for the info, I am learning (more by making mistakes than otherwise). I am embarrased to say this, but even tho I wrote it in my program "use 10k pullup on MCLR", I neglected to do it. Now that it is installed, things work like I expect.
    Jan 2006
    New Hampshire, USA
    I tried the pause loop and the stop command but both leave the oscillator running and the current draw is 800 microamps. I tried sleep $FFF with the watchdog timer turned off;this stops the oscillator and, after a few minutes, it settles down to 40 microamps current draw which is quite acceptable.
    >I tried the pause loop and the stop command but both leave the oscillator running and the current draw is...
    Yes, but getting the current down is moot because if you look at your logical flow when you get your hardware sorted out the PIC will switch itself off before you get to the STOP point... it's only until then you need a way of stopping you code, thereafter, if everything is working as it should, you'll never get to that point (well in reality you will but the PSU would be in the throws of shutting down anyway).
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  4. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  5. Replies: 4
    Last Post: - 7th September 2005, 14:11
