pic16c54a
Results 1 to 17 of 17
Thread: pic16c54a
    mavi's Avatar
    mavi Guest
    Default pic16c54 shema
    The third design (for 18-pin PIC) will match your requirements exactly and be the simplest to construct. You will also be able to use it for similar 18-pin PIC devices like 16F84 and 16F628.
    mavi's Avatar
    mavi Guest
    Default pic 16c54 tanks melanie
    yes i splitted it but i notfound programmer
    ic prog no supported
    ponyprog no supported
    which one do i use programmer?
    for help tanks
    I'm sorry, I can't help you with cheap or home-build programmers or software to drive them.
    mavi's Avatar
    mavi Guest
    Default pic16c54
    EVERYTHING, FOR, THANKS frends
