pic16c54a
Results 1 to 17 of 17
Thread: pic16c54a
    http://www.elnec.com/index.php
    Their programmers support 16C54... check this list...
    example 1. manufacturers list...
    http://www.elnec.com/manuf_list.php?...nk=jetprog.php
    example 2. microchip list...
    http://www.elnec.com/dev_list.php?pg...rochip_dev.htm
    You get what you pay for...
    If you are in Turkey...
    Infogate - Era Bilgi Sistemleri Yayincilik Elektronik San. ve Tic.ltd
    Mr. Gokhan Dincer
    Soyak Baglarbasi Evleri, B-3 blok D:3
    Baglarbasi, Uskudar, Istanbul 34664
    Tel: +(90) (216) 5300571 - 5300572 - 5300 573, Fax: +(90) (216) 5300 574
    E-mail: Infogate - Era Bilgi Sistemleri Yayincilik Elektronik San. ve Tic.ltd
    Web page: www.infogate.org
    mavi's Avatar
    mavi Guest
    Unhappy pic16c54 help
    for help tanks MELANİE bat is mashine 800euro and no support adapter
    im search easy programmer+ shema again tanks
    You never specified a budget... just said you needed a programmer for a particular device. I don't know what kind of adaptor you seek, but elnec pretty much manufacture every possible adaptor for almost any programming device in existance.
    The problem with going 'cheap' is you end up wasting so much time that you might as well have bought something better to start with.
    mavi's Avatar
    mavi Guest
    Default pic16c54 shema
    The third design (for 18-pin PIC) will match your requirements exactly and be the simplest to construct. You will also be able to use it for similar 18-pin PIC devices like 16F84 and 16F628.
    mavi's Avatar
    mavi Guest
    Default pic 16c54 tanks melanie
    yes i splitted it but i notfound programmer
    ic prog no supported
    ponyprog no supported
    which one do i use programmer?
    for help tanks
    I'm sorry, I can't help you with cheap or home-build programmers or software to drive them.
