How to program a 18F2455 with Velleman kit 8048 ?
Results 1 to 2 of 2
    PICPOC's Avatar
    PICPOC Guest
    Question How to program a 18F2455 with Velleman kit 8048 ?
    Hello,
    As I already got a 8048 Velleman kit, rather than purchasing a programmer, I'd like to use it to burn 18F2455 chips.
    I noticed that the hardware is compatible so I can use the board socket.
    But I'm looking for the programming parameters: which existing "config-word" must be used and which algorithm ?
    Maybe using several combinations may lead to success, but maybe to destruction ?...
    Which PIC can be considered as the nearest type ?
    I didn't find any precise information on Velleman website.
    Does somebody have already solved this question ?
    Thank you for your help.
    <Header of ProPic2 ini file>
    ,Controller Config Code Data LVP Alg Dev.ID
    PIC12F629 7 1024 128 N 4 Y
    PIC12F675 7 1024 128 N 4 Y
    picitup's Avatar
    picitup Guest
    I have used winpic to program 18f452 using ICSP with no problems.
    http://www.qsl.net/dl4yhf/winpicpr.html
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
