Dedicated LCD Controller question
Results 1 to 7 of 7
    Aug 2005
    Default Try this
    @ DEVICE PIC16F84A, HS_OSC, PWRT_ON, WDT_OFF, PROTECT_OFF
    DEFINE OSC 20 ' Set speed to 20MHz
    TRISB = %00000000 ' All PORTB pins are outputs
    ' LCD DEFINES
    DEFINE LCD_BITS 8
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4 'PORTB.0 is first data
    DEFINE LCD_LINES 2 'Number of lines on LCD to be used
    define LCD_RSREG PORTA 'Port used for LCD RS Pin
    define LCD_RSBIT 3 'Port Pin used for LCD
    define LCD_EREG PORTA 'Port used for LCD E pin
    define LCD_EBIT 4 'Port Pin used for LCD E Pin
    define LCD_COMMANDUS 2000 'Delay between sending lcd commands
    define LCD_DATAUS 50 'Delay time between data sent
    SerData VAR word
    SerPin VAR PORTA.2
    TRISA.2=1
    LCDOut $FE, 1 'Clear LCD
    pause 20
    lcdout $FE, 2 'Return to home position
    pause 20
    GOTO Start
    Start:
    SERIN SerPin,6,SerData 'receive data
    LCDOut Serdata ' Send to LCD
    If serdata =5 then gosub clearlcd
    GOTO Start
    clearlcd:
    lcdout $FE,$80," "
    lcdout $FE,$C0," "
    So if you send number 5 to your pic it will clear the lcd. From your code ive asumed you have use a 2 line lcd.
    Hope it helps
    Sphere
    lcdout $FE,$80," "
    lcdout $FE,$C0," "
    when I post the above it has 20 spaces between " " but it is only showing about 4 so add about 20 in your program
    Mar 2005
    Madison, WI, USA
    Default Lcd
    Thank you for your replies.
    I looked over many of the previous posts by searching this site and realized that my problem was most likely due to trying to use DEBUGIN for input. None of the code examples I saw utilized DEBUGIN. Finally I scrapped the 16F84 as processor, cut 4 data lines from my hardware interface and used a 16F628 with a USART. Using HSERIN (on RB1) as my input and LCDOUT with the 4 line mode, I had success last night.
    It looks like the SERIN command was used in one of the examples. Perhaps I will work with it and see what happens.
    I think a faulty crystal also complicated my debug process.
    In this exercise I learned what a huge amount of information is available on this forum but it helps to search on the correct terminology. Once I discovered that what I am trying to do is referred to as a "backpack", I had a lot of good material to look over.
  1. LCD with T6963C controller
    By Demon in forum Off Topic
    Last Post: - 22nd May 2022, 21:11
  2. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  3. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  5. LCD will not start
