Thhank you Melanie,
Iīt's working fine now.
As the manual says, I had to disable the interrupts to get it working fine.
With the interrupts enabled sometimes I just read 65535 as a result.
May I ask something else ?
I'm using Timer0 and Timer1 to count my pulses in this same project.
I would like to move to a 16F877 and get access to some analog ports.
My doubt is : Can I use ADCIN with interrupts or should I disable them to read the analog port ?
The PBP manual donīt say I need to disable interrupts on 16F87x series. Is it right ?
Thank you again .
Sérgio
