encode/decode manchester
Results 1 to 10 of 10
    a_critchlow's Avatar
    a_critchlow Guest
    Post encode/decode manchester
    could anyone explain this to me in more detail please?
    Encode:
    For i = 0 to 7 ' loop for 8-bits
    outword.0[(i*2)] = ~inbyte.0[i]
    outword.0[(i*2)+1] = inbyte.0[i]
    Next i '
    Decode::
    For i = 0 to 7
    outbyte.0[i] = ~inword.0[i<<1]
    Next i
    The main line i dont understand is: outword.0[(i*2)] = ~inbyte.0[i]
    thank you all for your time
    Quote Originally Posted by a_critchlow
    That means bit i*2 of outword be the NOT (the inverse of) inbyte bit i
    I don't get any of it.
    Please, someone, a manchester encoding for dummies tutorial.
    Do a SEARCH on 'manchester' on this forum and all will be revealed.
    a_critchlow Guest
    Exclamation ~inword.0[i<<1]
    ive figured out the encoded part but i cant get the decoded part into my head:
    if the counter is at 0, it should put the first bit of the encoded data inversed into the decoded data var. but because of the <<1 it puts the second bit inversed into the first decoded var.
    thanks.
    Don't bother. If you do not understand this code, there are many other codes doing the same thing. Or better, create your own.
    The idea is this: if you have to send 0 then in manchester you will send 01 pair. If you have to send 1 then in manchester you will send 10 pair.
    So, for the byte
    1 0 0 1 1 0 0 1
    the result would be:
    10 01 01 10 10 01 01 10
    Is it clear now? You can simply do an if-then-else sub routine for the encoder and also the same for the decoder (in reverse of course).
    As Melanie stated, a search will reveal much more. This case is trivial by now...
  1. 16F84/16F628 and Manchester
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 12th March 2009, 15:28
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. SERIN2 – SEROUT2 and Manchester mistake.
    By RCtech in forum Serial
    Last Post: - 4th September 2007, 22:55
  4. Manchester coding question
    Last Post: - 5th May 2007, 17:35
  5. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 13:31
