Is there an area for hardware items?
Results 1 to 10 of 10
    Mar 2005
    Madison, WI, USA
    Default Is there an area for hardware items?
    I wonder if there is an area to post a hardware related question. I understand if the answer is No due to the fact it is such a large scope.
    Just shoot with your question... you never know it might be of interest to somebody somewhere... this section is pretty good in which to ask it...
    Mar 2005
    Madison, WI, USA
    Default Hardware Problem
    After laying out and etching two boards and populating them with parts I now remember a problem I had a year ago trying to use two PIC16F84A's together on the same board. I finally got so frustrated with the business that I switched to another device with more pinouts (a 16F877, I think.)
    Last night I finally connected a secondary board with a PIC16F628A to the ground and 5VDC buses of a primary with another 16F628A. The primary has an LM7805 on it to source both PIC's. When tested apart, both boards run and test out perfectly.
    When I connect the secondary to the power buses of the primary, the PIC on the secondary board fails to operate. I have checked the Vss and Vdd pins on the secondary and I get 5VDC on Both!
    Here are the design facts:
    - Both 16F628A's are set to run on their respective internal clocks at 4MHz
    - Both 16F628A's have !MCLR enabled (pulled up with a 4700ohm external resistor) to be used as a manual pushbutton reset.
    - Comparitors ar disabled on both PIC's
    - I always solder a filter cap right under the socket across Vss and Vdd, in this case a mono. ceramic 1uF, 50v and did so on both PIC's.
    - Finally, I did not make the error of putting 5VDC on both pins of the power connector, and there are no circuit paths on the secondary board which would cause that. I am certain that all ground traces/pins end up at the 7805 center pin, and there are no shorts. The filter caps are the only bridges.
    This is really bewildering. I can't believe an industrial application of plc's wouldn't have a situation where multiple devices would be used together in the same sub-system so device isolation must be an art.
    Does anybody know why my PIC's don't ever play well together? Is there some harmonics problem between the two clocks that the filter caps. don't overcome? I've often wondered about this. I don't have the years of experience to recognize things like that (the art.)
    Feb 2003
    Quote Originally Posted by afbecker
    Sounds like a problem with the ground trace to the second board.
    You say it works fine on its own, so is the terminal you are taking ground from on the first board somehow rising to +5v when the first board is running?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mar 2005
    Madison, WI, USA
    Default More on 2 PIC NM
    Kieth,
    Well,
    I'll have to check that out this evening. It should be continuous to the 7805 center pin with no bridges but I could meter it nonetheless and see where that leads.
    I have had a reply from the MicroChip forum from a fellow who paralleled 4 PIC's together on the same bus and had no problems.
    My difficulty showed up at 1:00 a.m. so that may be part of it!
    Aug 2005
    Denver
    If it was me, I'd establish one single point as ground, probably the center pin of the LM7805. Then I'd check all the possible points on both boards with a multimeter to see if there's any DC bias. I agree that it sounds like something is wrong in the power distribution or grounding.
  1. < We need hints and tips area of forum >
    By electroken in forum mel PIC BASIC Pro
    Last Post: - 19th December 2009, 16:34
  2. multiple serin/serout items
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 27th April 2007, 23:47
  3. The Test Area Forum
    By Darrel Taylor in forum Forum Requests
    Last Post: - 1st July 2005, 18:35
  4. New Products & Sale Items
    By Bruce in forum Adverts
    Last Post: - 21st February 2005, 23:04
