what's wrong with this interrupt
Results 1 to 7 of 7
    pic model ?
    micro's Avatar
    micro Guest
    pic16f84
    sorry i forgot that
    Read portB on entry into the interrupt routine to end the mismatch condition.
    SomeVar = PORTB ' read portB
    Then clear the interrupt flag before exiting your interrupt routine.
    INTCON.0 = 0 ' RB port change int flag is cleared.
    Now whenever portB is different from the last value read, INTCON.0 will be set, and you'll vector back to your interrupt routine.
    Read this app note for more details:
    http://ww1.microchip.com/downloads/e...tes/00566b.pdf
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    micro's Avatar
    micro Guest
    i solved the problem with another method as below
    trisa=%00000
    trisb=%11111111
    option_reg=%10000000
    intcon = %10001000
    I var byte
    on interrupt goto int
    back: if portb<>0 then intcon=%10001000 ; test bit 3
    serout porta.0,2,[254,1]
    pause 10
    serout porta.0,2,["Hello"]
    disable interrupt
    int:
    for i=0 to 5
    pause 10
    serout porta.0,2,[#i]
    next i
    INTCON=%10000000 ; cleared bit 3 bit
    goto back ; back to test
    resume
    enable interrupt
    i will read document, thank u for that, and waiting a reply from Mister_e
    Micro,
    Maybe your solution is working but will Behave weird one day or another.
    I've nothing else to add from the Bruce's explanation. Everything is covered in his document.
    AND it's also covered in the PORTB TRISB section 3.2 of your datasheet too.
    BTW, why using interrupt on PORTB<7:4> if you never test wich pin gives you the interupt?
    Talking Other method ?????????????????????
    Quote Originally Posted by micro
    Just a longer way to read PORTB ... no other method here !!!
    Elegant solution would have been to display the port where the interrupt came from, in the "serout"
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
