12F509 programmer
Results 1 to 15 of 15
    Nigel say's he'll get some chip's and have a look at them but right now winpicprog won't do them.so we'll just have to wait till he get's some chip's
    i use often 12F508, 12F509 again. They're release since 1-2 year now.
    MAYBE you can use PIC12C508 in you programmer software... MAYBE.... worth a try.
    You know, this 12F509 has an internal oscillator....is this a problem for most of the programmers?
    Like I say, I don't keep up with all the part numbers and not a really frequent picbasic user.
    I think I should look at another part number that is compatible with my P16pro40 and forget the 12F509.
    Could anyone suggest a low cost, (2 to 2.50 neighborhood in quantity), basic PIC that is anywhere from 8pins up (actually the more I/O the better, so 14 to 18pin is no problem at all).
    Nothing fancy, just need some I/O pins to work with and an external xtal or rc.
    A flash part.....still vailable in a dip packeage and definetly COMPATIBLE WITH THE P16pro40?
    THANKS kindly for any part numbers....I'm just going to send these 12F509 back.
    New England
    The 16F628 is a nice basic chip with a fair amount of funtions and resonably low price (a bit more than the $2 range). 18 pin and programs fine in my home-made Pic16Pro programmer with either Picall or WinPicProg.
    Arch
    you could try 12f675,winpicprog does it and it's 8 pin
    Thanks folks....I think I'll get that 16F628A....only 1.65 for 100pc and 16 I/O to boot.
    I see it on the list of chips for my picall and p16pro so that's even better.
    Appreciate it.
    Jan 2006
    Toronto
    Good choice, I use the 16F628A in several projects using the internal osc and it works great.
    You should consider either making or buying a more universal programmer as well. It will come in very handy.
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 20:14
  3. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
  4. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 03:25
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 18:16
