18F2620 Interrupt
Results 1 to 3 of 3
    Sep 2003
    Vermont
    Default 18F2620 Interrupt
    Greetings all,
    I was using the hardware serial receive routine from the ME website for the 18F452 with great success. When I upgrade to the 2620, it won't work. Is there some interrupt difference I am not catching?
    Ron
    Ron Marcus, I have migrated one of my projects from 18F252 to an 18F2620 and the only things I changed were the A/D configuration settings as the definitions are a bit different. I use 38.4k baud interrupt driven receive and transmit routines enabled continously. Recheck the data sheet and make sure you have all of the interrupt registers set correctly and the USART registers set correctly.
    Sep 2003
    Vermont
    Thanks. I will look for a mistake in the code.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
