any idea what chip they use for MOTION TRACKING??
Results 1 to 6 of 6
    harrisondp's Avatar
    harrisondp Guest
    They probably use a LM1881 ( http://www.national.com/pf/LM/LM1881.html ) composite sync seperator chip to track which video line they are on. Then they probably take timed ADC samples on a block of lines and average them. The values are probably then stored in a 2d array which is then used to be compared with the next frames.
    This is not necessarily a difficult process or project other then the fact that you probably have to set a PIC ADC to the fastest conversion time, which might be fast enough for what you need.
    You will most likely have to use ASM or maybe a very very very efficent c compiler. You will also have to use some really really tight loops to track video lines and read adc values.
    If it was me, I would have prolly used some sort of faster processor like a SX. This would allow better timing for video processing.
    I was actually going to try this once, but I never got around to placing an order for a LM1881 (I'm just a poor high school student).
    Harrison
    forgie's Avatar
    forgie Guest
    Harrison looks like he knows what he's talking about. Follow his lead.... I've never worked with video, so my generic data acquisition block diagram may or may not have been helpful to you.
    Good luck with it.
  1. dialerf chip NTE1691
    By lerameur in forum General
    Last Post: - 30th April 2008, 00:01
  2. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  3. help with rf cc1000 chip
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 17th November 2007, 21:16
  4. Replies: 5
    Last Post: - 18th July 2007, 11:43
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
