Decoding DMX with picbasic pro
Results 1 to 9 of 9
    Jan 2006
    Smile Decoding DMX with picbasic pro
    hello,
    I have studied the posts concerning dmx with picbasic, I want to dimming a led on portC.5 on a 18F452. I try this basic code but unfortunately it doesn't run.
    the dmx is converted by a driver SN75176 connected on pin 26 (RC.7/RX/DT). Please is someone can look my code for help me.
    sorry for my bad english i'm french.....
    greating
    '*  Notice  : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 26/01/2006                                        *
    DEFINE OSC 16             ' for pic 18f452
    DEFINE HSER_BAUD 250000
    DEFINE HSER_CLROERR 1
            ERRORLEVEL -306, -302
    ' Variables diverves
          counter        VAR word                ' Variable de travail WORD
          idleflag       VAR WORD
          dummy          VAR WORD
          RCIF           VAR byte
          startcode      VAR WORD
          aminus         VAR WORD
          adresse_grada  VAR WORD
          x              VAR WORD
          newlevel1     VAR WORD
    adresse_grada = 20
    'This next routine is called on a gosub from my main housekeeping loop:
    checkdmx:
    counter = 1 'just a dummy variable
    pulsin portc.7,0,counter 'here I'm looking for the break signal
    if counter = 0 then
        idleflag = 1 'either no dmx, or break was too long to count
        'return
    if counter < 40 then checkdmx 'watching for 'break
    'if you get here, an active low pulse was detected, but it was too short.
    'probably just part of the datastream. So go back and look again.
    'otherwise, a valid break was found and it's time to read the start code
    dummy = RCREG 'clear out any garbage which may be in the USART
    dummy = RCREG
    SPBRG = 0
    TXSTA.2 = 0 'brgh = 0
    TXSTA.4 = 0
    RCSTA.7 = 1
    RCSTA.6 = 0 'setting 8 bit receive mode, no parity, etc
    RCSTA.4 = 0 'check the datasheet to see what all these bits do
    RCSTA.4 = 1 'now, the USART is on and ready to receive
    while RCIF = 0:wend 'hover here after break, before start code
    startcode = RCREG 'This is the first byte received after the break
    if startcode <> 0 then checkdmx 'do your own stuff here on a non-zero code
    aminus = adresse_grada - 1 'address1 is my target address
    for x = 1 to aminus 'set up a loop to count almost to the address
    while RCIF = 0:WEND 'sit here until a byte is received
    dummy = RCREG 'stash the byte somewhere unimportant
    next x
    newlevel1 = RCREG 'This is your target channel data
    pwm portc.5, newlevel1 ,100  'i want dimming a LED on PORTC.5
    RCSTA.7 = 0 'turn off the USART
    goto checkdmx
    Apr 2005
    http://www.melabs.com/resources/samples.htm
    here is a program for dimmer may be helpful for you?
       ' Lamp dimmer
        ' File name : LampDim.bas
        ' Company : Mister E
        ' Programmer : Steve Monfette
        ' Date : 23-12-2004
        ' Device : PIC12F675
        ' This program is use to dim intensity of an AC line load
        ' like lamp, motor and other.  Developped for 60 Hz line.
        ' This allow to increase or decrease intensity.
        ' If the user doesn't held at least 0.5 sec:
        '    1. "Increase" : we will set the output for full brightness
        '    2. "Decrease" : we will turn off the output
        ' The software need :
        '     1. A full wave signal from the AC line on GP4
        ' The software use :
        '     1. TIMER1 overflow to check if pushbutton are hold for
        '        more than 0.5 Sec
        '     2. Interrupt on GP4 (AcLine input) to synchronise Triac
        '        Device programming mode and hardware definition
                 ' Using Internal Clock, no clock out
                 ' Enable Watch dog timer
                 ' Disable MCLR pin
                 ' Enable Power-up timer
                 ' Enable Brown-out detect
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _PWRTE_ON & _BODEN_ON
    TRISIO = %11111011
    OPTION_REG.7=0    ' Enable pull-ups
    WPU=%00000011    ' Enable pull-ups on GP0, GP1
    CMCON=7    ' Disable analog comparator
    ANSEL=0    ' Disable analog converter
    Pb_Inc    var    GPIO.0 ' Input for INCREMENT/ON push button
    Pb_Dec    var    GPIO.1 ' Input for DECREMENT/OFF push button
    Triac    var    GPIO.2 ' Output to TRIAC gate
    ACLine    var    GPIO.4 ' Input for the FullWave rectify AC line
        '        Software definition
    MaxDelay                    var word
    TriacDelay                  var Word
    Debounce_AutoRepeatDelay    var    word
    FullBright                  var bit
        '        Interrupts definition
    INTCON=%10001000 ' Enable interrupt on GPIO change
    IOCB.4=1         ' Enable interrupt on GP4 change
    PIE1.0=0          ' disable TMR1 overflow interrupt
    T1CON=%00110100  ' Set TIMER1
                     ' prescaler 1:8
                     ' internal clock (Fosc/4) 1MHZ
                     ' synchro internal
                     ' we will use TIMER1 overflow
                     ' $ffff * 8* (1/(4MHZ / 4)) = 0.524 Sec
    ON INTERRUPT GOTO ACDetect
       '          Hardware and variable initialisation
    Maxdelay=6000 ' Set Maximum delay (set to 8000 for 50Hz)
    FullBright=0  ' disable Full Brightness flag
    triac=0       ' disable Triac Gate
    triacdelay=0  ' Set delay to minimum
    gosub ResetTimer1 ' reset Timer1
       '      Main
       ' Get entry from user to Increment of Decrement intensity
    start:
       ' Test Increment push button
       ' If hold more than .5 Sec, increment triac gate delay by 500 uSec
       ' case else Full brightness at output
    while Pb_inc=0
        gosub TestTimer1 ' test status of TIMER1
        while (Pb_inc==0) AND (PIR1.0==0) 'loop while holding push button
                                          'and no TIMER1 overflow
        wend
        if PIR1.0==1 then ' If timer overflow (pushbutton hold for > 0.5 sec),
            T1CON.0=0     ' disable TMR1
            gosub Debounce_AutoRepeat
            if (triacdelay<maxdelay) then="">
                triacdelay=triacdelay+500 'increment Triac gate delay
                triacdelay=maxdelay ' if triacDelay>MaxDelay,
                fullbright=1        ' set the full brightness Flag
            triacdelay=maxdelay ' If pushButton was hold less than .5 sec
            Fullbright=1 ' Set the full brightness flag
    wend
    gosub ResetTimer1
       ' Test Decrement push button
       ' Case else, turn off output
    while Pb_dec=0
        gosub TestTimer1 ' Test status of TIMER1
        while (Pb_dec==0) AND (PIR1.0==0) 'loop while holding push button
        wend
            T1CON.0=0 ' disable TIMER1
            if (triacdelay>0) then
                Fullbright=0 ' Reset TRIAC always ON flag
                triacdelay=triacdelay-500
            triacdelay=0
    wend
    gosub ResetTimer1
    goto start
        '     TestTimer1
        ' Enable TIMER1 if :
        '    not enable and not in overflow
    TestTimer1:
        if (T1CON.0==0) AND (PIR1.0==0) then 'if TIMER1 not enable
                                             'and TIMER1 not overflow
            T1CON.0=1 'enable TIMER1
        '     ResetTimer1
        ' Subroutine to clear Timer1
        '    1. Overflow flag
        '    2. Disable Timer
        '    3. Clear counter
    ResetTimer1:
    PIR1.0=0  'clear timer overflow
    T1CON.0=0 'disable timer
    TMR1L=$00 'clear counter
    TMR1H=$00 '
        '     Debounce_AutoRepeat
        ' Subroutine to debounce push button.
        ' Also provide kind of auto-repeat when push button
        ' are held down.
        ' each delay = 20 mSec
        ' Use of PAUSEUS to be sure getting ACLine interrupt
    Debounce_AutoRepeat:
    for Debounce_AutoRepeatDelay=1 to 2000
        pauseus 10
    next
        '       ACDetect
        ' Interrupt routine called by ACLine (GP4) pin state change
    disable
    ACDetect:
    if ACline==1 then ' Check for rising edge of AC signal
        if triacdelay > 0 then
            Triac=1 ' Activate TRIAC
            if FullBright==0 then   ' In case Brightness flag is not set
                pauseus triacdelay  ' do the selected delay
                triac=0 ' Disable TRIAC
            triac=0
    INTCON.0=0 ' Clear GPIF (interrupt on GP4 change)
    resume
    enable
    </maxdelay)>
    Jan 2006
    Smile thanks
    Thanks for your answer,
    My problem is more decoding DMX frame with picbasic , firstly I try to detect the break at the beginning of the dmx frame....
    Thanks too for the link.
    Greeting
    Jan 2006
    Default Yes i find a break
    Hello,
    I find a break
    but i don't understand the RCIF fonction!!
    I think that RCIF is my problem because he is always at 0 thus RCREG he is already full !!
    How made for use the RCIF??
    Greeting
    Nov 2004
    Have you read the chapter about the USART in the datasheet? It takes a few tries for it all to sink in, usually.
    If you're reading zeros, that means it's either empty, or it actually thinks a zero was received.
    Depending on how you've structured your code, you may consider turning OFF the USART while you look for the break.
    Once you've found the break signal, turn on the USART and clear it a few times, just to make sure it's ready for whatever data you're hoping to capture.
    JEC
    Jan 2006
    Default the code
    Hello,
    Can you say to me if my code is good for the definition of the variables (rcif)and if there are not other errors.
    Thank you
    '* Name : UNTITLED.BAS *
    '* : All Rights Reserved *
    '* Version : 1.0 *
    '* Notes : *
    DEFINE OSC 20 ' for pic 16f627
    idleflag VAR WORD
    dummy VAR WORD
    RCIF VAR byte
    startcode VAR WORD
    aminus VAR WORD
    x VAR WORD
    newlevel1 VAR WORD
    adresse_grada = 20   ' my adress for exemple 20
    checkdmx:
    pulsin portB.1,0,counter 'here I'm looking for the break signal
    if counter = 0 then
    'return
    dummy = RCREG
    SPBRG = 0
    TXSTA.4 = 0
    RCSTA.7 = 1
    next x
    portA.2 = newlevel1  'i want dimming a LED on PORTA.2
    goto checkdmx
  1. ICD, ICSP and Picbasic Pro
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 8th August 2024, 21:42
  2. How to configure SPI in PICBASIC PRO?
  3. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  4. DMX & PicBasic coding problem
    By magicmarty in forum mel PIC BASIC Pro
    Last Post: - 20th September 2004, 16:35
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
