On Interrupt question
Results 1 to 16 of 16
    Feb 2005
    Kolkata-India
    Default Why have you turned on Timer0 Interrupt
    On a closer look at your prog I found that you have timer0 to use external clock via RA4. Possibily you did this because there is no timer0 enable disable bit. You wanted your timer not to work. But you have kept the input floating. Spurious counting is going on. Also you have turned on the timer0 interrupt bit in your intcon settings. So a timer0 overflow would trigger the interrupt.
    So my suggestions :
    1. Disable the T0IE bit
    Sougata
    Feb 2005
    Talking
    Thanks Sougata, I changed that bit and now it works as expected.
    A single bit keep me puzzled half week, you gotta love pics...
    Here is the working example, so others can learn too:
    @ device pic16F628A, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    trisb   =%11111111
    trisa   =%00000000
    cmcon   =%00000111  'Comparators Off
    vrcon   =%00000000
    intcon  =%10001000'interrupts enable // was  %10101000
    'OPTION_REG =%11010001
    but1    var PORTB.4
    but2    var PORTB.5
    ledwork var PORTA.0
    led1    var PORTA.1
    led2    var PORTA.2
    led3    var PORTA.3
    rs      var PORTb.2
    conta   var byte
    porta=0
    portb=0
    on interrupt goto interrupcion
    SerOut rs,2,[" ",10,13]
    SerOut rs,2,["Begin",10,13]
    LOOP:
    SerOut rs,2,["Loop",10,13]
    for conta=0 to 255 step 16  'working led rise routine
        pwm ledwork, conta, 10
    next conta
    high ledwork
    for conta =0 to 10
        pause 10
    next conta
    low led1   'set button status leds off
    low led2
    low led3
    goto loop
    disable
    interrupcion:
    SerOut rs,2,["Interrupt",10,13]
        intcon.0=0
        intcon.1=0
        intcon.2=0
            if but1=1 then
                 but1=0
                high led1
                SerOut rs,2,["Set",10,13]
            if but2=1 then
                 but2=0
               high led2
               SerOut rs,2,["Mode",10,13]
    high led3
        resume
    enable
    I commented out the OPTION_REG because the program worked ok with and without it. Of course the serouts can be removed, I use them to know where the program is.
    Thanks to all for the help provided
    Pablo
    Feb 2005
    Kolkata-India
    Thumbs up All's well that ends well
    In helping you out I also added my experience. It really feels good when a puzzle gets solved. If you hadn't given the hints that it is jumping to the interrupt even without a button pressed I couldn't have pointed it out. So the credit goes to you for all the labour and time spent.This is only the beginning now concentrate on the PWM part and add some sparkle to your design.
    I myself do not rely on the PBP interrupt and tend to use asm as my apps demand.It is not that tough if you give it a try. I am a complete self-taught without much of an academic background. My schedule doesn't permit me always to be active in this forum still I love to.
    I am myself very much facinated with RGB LEDs and plan to design an ambilight as in the Phillips plasma TVs. (I cannot afford a LCD or Plasma)But everytime my hobby gets the least attention due to job pressure. I am still in my struggling phase to establish myself as a PIC programmer. I live in a city where neither PICs nor RGB LEDs are easily available. I have to get them from another metro and it is costly in terms of our economy. Still with all of you around I know I am not alone. Thanks to this forum and all PICers out there.
    Have a great PICing time.
    Sougata
    Feb 2005
    Talking
    Here is what I did with the previous version that did not used interrupts, just a simple loop of 6 for-next:
    What happens when you mix: A toilet scrub and a vase
    I hope you didn't bet on this art deco artifact :
    Well, you need to add some electronics to the mix: a pic microcontroller, some mosfets, a few resistors, a few luxeon leds, a heatsink, a difuser and a li-ion battery...
    and you get this:
    luxeons attached to heatsink and difuser over leds:
    here is a sequence of frames:
    If you can view DivX files, here is the complete color sweep (480k)
    Hope you all like it
    Pablo
    Feb 2005
    Kolkata-India
    Thumbs up Great!!
    Hats off to your vase. Nifty stuff. How about adding a beat detector with a mic input that adapts your PIC to music playin around.
    Sougata
  1. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 20:12
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. USART interrupt not interrupting right
    Last Post: - 6th March 2005, 01:07
  5. Interrupt question
    By stone in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 23:11
