On Interrupt question
Results 1 to 16 of 16
    Feb 2005
    Question On Interrupt question
    Hi, im trying to understand how to use ON INTERRUPT, so I created this little program:
    @ device pic16F628A, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    trisb   =%00110000
    trisa   =%00000000
    'ansel   =%00000001
    cmcon   =%00000111  'Comparators Off
    vrcon   =%00000000
    intcon  =%10101000  'interrupts enable
    OPTION_REG =%01010001
    but1    var trisb.4
    but2    var trisb.5
    ledwork var trisa.0
    led1    var trisa.1
    led2    var trisa.2
    led3    var trisa.3
    rs      var trisa.5
    conta   var byte
    on interrupt goto interrupcion
    ;SerOut rs,2,[10,13]
    ;SerOut rs,2,["inicio"]
    enable
    loop:
    ;disable
    ;SerOut rs,2,["Loop"]
    ;enable
    for conta=0 to 255 step 16  'working led rise routine
        pwm ledwork, conta, 10
    next conta
    high ledwork
    for conta =0 to 100
        pause 10
    next conta
    low led1    'set status buttons leds off
    low led2
    low led3
    for conta=0 to 255 step 16  'Fall routine
        pwm ledwork, 255-conta, 10
    next conta
    low ledwork
    for conta =0 to 100
        pause 10
    next conta
    low led1   'set button status leds off
    low led2
    low led3
    goto loop
    disable
    interrupcion:
    ;SerOut rs,2,["Interrupt"]
        intcon.0=0
        intcon.1=0
        intcon.2=0
            if but1=1 then
                but1=0
                high led1
            if but2=1 then
                but2=0
                high led2
    high led3
        resume
    enable
    The idea is to trigger an interrupt when any of the buttons (but1 & but2) are pressed, to show the status a led (led1 & led2) is turned on for a second and off again. led3 is used as a way to know an interruption has been triggered.
    To simulate a real loop the "payload" of the program is a PWM pulse on ledwork
    There are serouts all over the place, but since I cant make the basic version to work, these are commented out.
    IMHO this program should work, but it doesn't. Could someone guide me in the right direction to fully understand how this should work?
    Thanks!
    begin by changing this
    but1    var trisb.4
    but2    var trisb.5
    ledwork var trisa.0
    led1    var trisa.1
    led2    var trisa.2
    led3    var trisa.3
    rs      var trisa.5
    to
    but1    var PORTB.4
    but2    var PORTB.5
    ledwork var PORTB.0
    led1    var PORTB.1
    led2    var PORTB.2
    led3    var PORTB.3
    rs      var PORTB.5
    Let's see what happen now. i didn't go deeper than this.. for now
    Feb 2005
    I changed as you suggested but corrected the ports, I guess this is what you meant
    but1    var PORTB.4
    but2    var PORTB.5
    ledwork var PORTA.0
    led1    var PORTA.1
    led2    var PORTA.2
    led3    var PORTA.3
    rs      var PORTA.5
    And before the loop starts I added:
    porta=0
    portb=0
    Now I can see the led1/led2 trigger after pressing for about a second, but the generic interrupt led3 is ON all the time which indicates me that the interrupt is being triggered constantly, regardless of the button presses.
    Any idea?
    Pablo
    Feb 2005
    Im still puzzled by this, I know I must be near, but Im missing the finish line by a byte or two
    Thanks, help is appreciated
    Feb 2005
    Kolkata-India
    Default A quick look at your prog.
    You are turning on the LED3 in the interrupt routine and turning it off in the main loop. So technically it should work. Now consider this :
    Your buttons are not debounced so it may quite happen that another rising edge is setting up your interrupt. Since you have the buttons pressed while in interrupt you are being able to detect it and light led1 and led2.
    So introduce a pause inside your interrupt after turning on the LEDs and as soon as you inside the interrupt release the button. Then while getting out clear the interrupt flags. This might solve your problem.
    Sougata
    Feb 2005
    Quote Originally Posted by sougata
    Sougata
    Hi Sougata,
    If I enter any pause in the interrupt routine (I just tried it) I severelly impair the PWM loops, and this is another indication that the interrupt is being triggered constantly.
    Here is the schematic:
    Pablo
  1. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 21:12
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. USART interrupt not interrupting right
  5. Interrupt question
    By stone in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 00:11
