math help
Results 1 to 4 of 4
Thread: math help
    houa's Avatar
    houa Guest
    Default math help
    if any can help i would really appreciate it
    here's the problem
    A=.082
    B=4.15
    C=94.2
    D=76.76
    AA=A*B
    BB=C*D
    X=-75.12+AA-BB
    E=101
    CC=E*E
    F=EE/301.6
    Y=F*703
    I read that pic basic pro doesn't support floating point numbers
    so how can i approach this problem?
    Is there an include file i can include to my problem?
    Is there a procedure to follow to calculate my answers
    I need to display it with 3 decimals places as well
    Any help will be appreciated
    thanks for looking
    Bombay, India
    Default Long integers arithmetic
    This is a typical problem of small systems which do not have native floating point support / coprocessors.
    Perhaps you should consider using 24/32 bit integers for this function. You will have to write your own functions for this or search for an app note which does this. Alternately, you may look at the microchip website for the floating point code and port it to your application though I can say it will be a lot of code and slow at that.
    To do the long integer math, you can multiply each number by 1000 and then compute the result. When you get the result, divide it by 1000 to get the integer part and keep the modulus of 1000 as the fractional part to display
    Jerson
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Wink Arithmetics ???
    Hi, Houa
    The first step is to use the brain ...
    by multiplying a per 1000 and B per 100 ... you get integers, and so on.
    AA = 34 030 * 1E-5
    BB = 7 230 792 * 1E-3 ... over 16 bits, so,The second step is to define the precision of the result you want ...
    X = - 7 305.5717 ok ... but what is the real meaning of the last digits ???
    Here you find THE GOOD QUESTION ....
    10 Bits for an ADC or DAC is .1 % ...
    12 Bits ......................... is .025%
    do you know lots of Pic level peripherals with a better accuracy ??? Do you know how to realise those circuits ???
    so, 1 of 12 bits of your result is 1.8, say 2 ...
    .5717 really do not mean anything here, in the real world !!!
    Now, If you really want to do maths for maths ...
    Have a look to Melabs site, you'll find two valuable solutions
    1) Microchip FP files to " include" to your program
    2) arithmetic co-processor ... wich is the most simple Way.
    The last solution is to change compiler ( no, no ... not on the head ) or processor ... where those solutions are already cooked implemented.
    Hope it helps you to better see the truth !!!
  1. Resolution integer math assistance?
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 14th January 2010, 03:01
  2. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 04:20
  3. Pulsin Math question
    Last Post: - 2nd April 2008, 16:15
  4. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 10:22
  5. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 20:20
