distance sensor
Results 1 to 3 of 3
Thread: distance sensor
    jessey's Avatar
    jessey Guest
    Hi Nikos,
    You should get the book called "Experimenting with the PICBASIC PRO compiler" by Les Johnson. He has an example program called SON_PROX.bas complete with schematics and explanation. It uses 2 ultrasonic transducers modulated at 40 kHz. The circuit uses an op-amp to amplify and convert the received sound into a TTL voltage and a transistor to adjust the sensitivity back to the pic. That's a pretty low parts count. He's using a PIC16f84 micro so a 628 will work. He reports that his set-up will give a sensitivity of approximately two feet. Ultrasonic transducers are what most of the commercial units use for back-up sensors if I'm not mistaken. Let me know how you make out.
    Good Luck
    jessey
    Feb 2005
    GREECE
    I have just find the book you suggest me.
    I will look on it and I will let you know.
    Nikos
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Sharp ir distance sensor
    By hasnannordin in forum mel PIC BASIC Pro
    Last Post: - 11th October 2009, 22:48
  3. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 10:01
  4. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  5. Color sensor distance problem
    By burak450 in forum Off Topic
    Last Post: - 20th October 2008, 19:05
