distance sensor
Results 1 to 3 of 3
Thread: distance sensor
    Feb 2005
    GREECE
    Default distance sensor
    Hello boys and girls,
    I am looking for a distance sensor making a parking system for my car.
    Does anyboby suggest me any sensor using it with 16f628.I want to keep the cost down.
    Nikos
    jessey's Avatar
    jessey Guest
    Hi Nikos,
    You should get the book called "Experimenting with the PICBASIC PRO compiler" by Les Johnson. He has an example program called SON_PROX.bas complete with schematics and explanation. It uses 2 ultrasonic transducers modulated at 40 kHz. The circuit uses an op-amp to amplify and convert the received sound into a TTL voltage and a transistor to adjust the sensitivity back to the pic. That's a pretty low parts count. He's using a PIC16f84 micro so a 628 will work. He reports that his set-up will give a sensitivity of approximately two feet. Ultrasonic transducers are what most of the commercial units use for back-up sensors if I'm not mistaken. Let me know how you make out.
    Good Luck
    jessey
    Feb 2005
    GREECE
    I have just find the book you suggest me.
    I will look on it and I will let you know.
    Nikos
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Sharp ir distance sensor
    By hasnannordin in forum mel PIC BASIC Pro
    Last Post: - 11th October 2009, 21:48
  3. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 09:01
  4. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 00:05
  5. Color sensor distance problem
    By burak450 in forum Off Topic
    Last Post: - 20th October 2008, 18:05
