12F629 help
Results 1 to 5 of 5
Thread: 12F629 help
    Sep 2005
    California USA
    Cool 12F629 help
    I have wired up a 12f629 to flash some LEDs on the GP0 and GP1 pins and I also use a 4 Mhz Xtal on GP4 and GP5.
    The code I wrote is
    loop:
    high GPIO.0
    pause 750
    low GPIO.0
    pause 750
    high GPIO.1
    pause 750
    low GPIO.1
    pause 750
    goto loop
    But when I power it up it dose nothing.
    Can someone help.
    Willie
    Feb 2005
    Dont forget to set the analogue ports to digital.
    I believe it to be cmon = 7
    Pete
    AND be sure you correctly set the config fuses. See the FAQ about that.
    Sep 2005
    California USA
    Cool 12F629 help
    Pete and Steve thank for your reply.
    Pete I do have the cmcon = 7 at tie top of my code.
    And Steve I set the fuses to XT,MCLR to reset,Watchdog Timer on,Power-up Timer off.
    But I still don't get anything.
    Willie
    Sep 2005
    Dayton, Ohio
    Set MCLR to OFF, so it is an I/O pin, (otherwise you need a 5K resistor from MCLR (GP3) to +5V). Depends on your application. Do you need RESET? If not, then disable it and you get another input to use (GP3).
    CMCON = 7 ' this turns the COMPARATOR off
    ANSEL = 0 ' this turns the A/D convertors off
    And don't forget that if you decide to use GP3 it is INPUT ONLY.
    BTW - ALWAYS read the Datasheet!!! Look at the first few pages where is shows all the functions for each pin (especially the pin that is causing problems). If there are more functions than just "I/O" then you MUST go to those sections in the datasheet to see what the defaults are. Usually I/O is NOT the default. It's a little tedious at first, but saves a lot of headaches later. And usually you will find the answer quicker than asking here (but when you are really stuck, this forum is a life saver).
    regards,
    Jim
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
  1. Input problems with 12F629?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th April 2018, 07:25
  2. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 23:33
  3. 12f629 config settings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 23:39
  4. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 05:06
  5. Servo control with 12F629
    Last Post: - 24th June 2005, 00:34
